Question about Panasonic SC-HT740 System
F61 error code
How do i repair the audio amplifier ic ?
  • 788 Answers
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Posted on Jul 12, 2009
    New Friend:
  • 4 Answers
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn off. I checked my fan on sub. and check cable speakers, but still doesn't work. Can i get help for this problem, thank you!
Posted on Oct 17, 2013
Panasonic error f61
If you do not know what an audio output IC is, what would ordering one do for you? And unless you have the know how and special gear there is no freaking way you could ever replace it.
Either have someone repair it for you or go shopping.
Aug 17, 2017 | Audio Players & Recorders
IT IS SAY F61 AND CUT OFF
F61 Error Code Indicates a Protection Mode....Amplifier IC is possibly bad.
Oct 29, 2010 | Audio Players & Recorders
F61 error message
F61 IS THE ERROR CODE FOR A FAULT IN THE AMPLIFIER STAGE OF THE UNIT, if the power fan or supply is okay then THE MOST LIKELY CULPRIT IS THE AUDIO OUTPUT IC, WHICH IS A MULTI LEGGED DEVICE SCREWED TO A PIECE OF METAL USED TO COOL IT, IN PANASONICS ITS PREFIX WILL PROBABLY BE "RSN" BUT IT COULD BE "STK", MAKE A NOTE OF THE NUMBER AND SEARCH ON LINE, DONT FORGET TO CLEAN OFF THE OLD HEATSINK COMPOUND ON THE HEATSINK AND REPLACE WITH FRESH.f61 means theres is a fault with audio output ic, usually there is dc on one of the speaker output rails, replacing the audio output ic will usually cure this but check speakers and leads for shorts before reconnecting to the unit
Sep 28, 2009 | Panasonic Televison & Video
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
Technics F61 error, can you please tell me what this means?
F61 is the "shorthand" for protection mode for Technics units. Either the regulator IC or the output AMP-PAC IC has failed. Expect a parts cost between $40 -$100 for the repair depending upon which IC has failed.
Dan
Jun 19, 2009 | Technics Audio Players & Recorders
Error
The audio amplifier IC are damaged.
Aug 20, 2008 | Panasonic SC-AK17 Shelf System
F61 error
Hello....
Isolate problem by disconnecting Amplifier ic (RSN),if f61 still appeares after disconnection of RSN ic ,than check voltage supply rails ,may be one of them has irregularities.
Gopali
Dec 14, 2007 | Panasonic SC-AK300 CD Shelf System
F61
Sound amplifier ic??******** this guy is talking out of his ***.
F61 relates to fan error. There are two fans, one of them is either spinning too slowly or not at all.
This fan can be purchased in any computer store. Just remove it and take it with you.
Jul 28, 2007 | Technics SC-DV290 System
Panasonic SC-HT740 System Logo
1,260 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
