Question about Dryers
I can here the motor try to run but it will not spin. I was using the dryer and when I removed one load and replaced it with a new load all it does is make a hum. The dryer is only 2 1/2 years old.
  • 58 Answers
Dryer belt is either broken, or came off of the motor pulley, check varify and replace if needed. If belt is ok, you may have an article of clothing stuck in the blower wheel, remove as needed.
Posted on Jul 01, 2009
I have an Amana front load dryer. When I try to run it, i get a low hum noise for a few seconds, then nothing. The dryer won't run, the drum won't spin. Any advice?
When you get the hum, is the drum moving? It sounds like the motor is not turning. Can you spin the drum freely by hand? IF so, the belt may be broken. If not, you may have a bad motor. If you aren't handy, I'm afraid you're going to have to call appliance repair service, or think about getting a new or different dryer.
Sep 13, 2013 | Dryers
Dryer motor just hums, doesn't spin, kenmore front loading dryer
Try turning the drum by hand with the unit turned off. If it seems fairly easy to turn, then check the motor to see if it has a capacitor (about 2 to 3 inches long and 1 inch in diameter with two connections).This capacitor is used by the motor for starting. Replace the capacitor. If the drum is very hard to turn, something may be jamming the drum or the motor bearings may be frozen (new motor). Hope this helps.
Sep 26, 2009 | Dryers
Whirlpool Dryer not spinning.
Sounds like the motor is not getting to proper speed. As long as you check for things in the blower housing and bad idler and support bearings before buying a motor. It could be motor bearings or weak windings. Replacing the motor is not a simple task and involves removing the front and the blower. Make sure it is the motor as most places will not take returns for electrical components.
Eric
Jul 06, 2009 | Whirlpool LER5636P Electric Dryer
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Jan 02, 2009 | Whirlpool ET8CHEXSQ Dryer
Candy CNW156 washer/dryer: spins empty, won't spin under load
If the belt and the motor are OK, then tell your friend to check the motor coupler, the MCU (motor control unit).
See also the following link : It doesn't spin.
Dec 01, 2008 | Candy CNW156 Front Load Washer / Dryer
Dryer won't spin
step 1- remove the face of the dryer, then remove the cover for the fan, check to see if object is blocking the fan, if object is there , remove object, if not go to step 2
step 2- check to see if the belt is broken, if the belt is broken replace the belt.
step 3 - remove the belt from the motor and turn the dryer on, if the motor doesn’t turn then you need to replace the motor.
Jan 01, 2008 | LG DLG5988 Gas Dryer
Dryers Logo
43 people viewed this question
Top Dryers Experts
