Port 1 works, port 2 dead. Audio from port 1 starts buzzing after about an hour.
You are in need of the a board inwhich you can more than likely install yourself. Make sure the power is not plugged in when you do it. The board that you need is Panasonic TZT/A10QXL (TNPH0856AC) A Board for TC-L32C22
There are lots of different places you can look to get one. Usually, the cheapest method is off ebay or retech
Regards,
Joe Van Buren
SOURCE: Panasonic TH-42PX60U HDMI stopped working
Please unplug TV from AC outlet and replug it after 5 minutes then check HDMI port.
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Testimonial: "Thank you for giving me another avenue to explore."
SOURCE: the hdmi ports (2) do
Tries tv unplug replug it back like an hour later for a tv resetting itself.The HDMI (2) port might be working again.Just used the PS3 game system only conennected it in the different tv ports of for the HDMIS ports provided by the tv.U know this wright?The PS3 game system play all this funsctions.CD-Audio only,DVD movies and old PS1 games,some PS3 system may,may not support and play old PS2 games,All Blu Ray movies and All PS3 Blu Ray games.
SOURCE: no hdmi signal on a panasonic viera tv, they used to work
sounds like you need to update firmware
SOURCE: I cannot install a new PS3 Slim to a Panasonic
found out how ok go to a tv thats ur ps3 works on go to 1080p and click it while the 30 second marker starts you quickly turn off ur ps3 and and plug everything back onto the panasonic and go to hdmi1 or 2 and it should work it worked for hopefuly it works for you guys to
