Question about Peerless Industries Peerless& Single Handle Tub & Shower Faucet
It is leaking, how do I get it off to replace seals
  • nwagner42 May 11, 2010
    What is leaking, the shower head, or the shower handles
  • 20 Answers
First turn off water to house or bathroom,you will need Hex key set (Allen Wrench Set) and a pair of channel locks and a Phillip and Flat head screw driver, place something over the drain line so that no parts fall down drain then you will notice under the handle you will see either a hole or a small piece of plastic that that you can pluck out with a flathead screw driver thats where you will find the allen key screw its very small, once you remove that you can remove the front have of the handle wiggle it off, then take your channel locks and remove the thin nut that holds the big round silver part down, you will then remove the stem that the handle was attached to You can then pull out the divertor and take it with you to home depotand either replace the whole thing under $20 or find the parts under $10
Posted on Jul 16, 2009
A/C compressor front seal leaks 134a. Can the can of 134a with leak sealer really seal the leak?
No, the stop leak is designed to seal a leaky O-Ring. I have never seen anything fix a compressor seal other than replacement.
May 17, 2016 | 1997 Ford Expedition
Bellhousing leak
did you just have the fluid replaced in the transfer case?? if the answer is no, the you may have a leak from the series of seals that are internal. you will have to have the transfer case removed and have the CVT seal replaced and other seals inside of the transfer case. lengthy repair and costly also. the transfer case has to be removed to replace the CVT side seal and while you are in there replace seals inside of the transfer case also. that what its sounds like to me. transfer case seal leak or the inside CVT seal leak. however if its leaking right from the bellhousing, it also could be the torque converter seal. this is when proper diagnosis comes to play. if its d converter seal, than the trans has to come out. have this one checked by someone that knows what they are doing. could be transfer case seal leak and it could be converter leak.
Jul 12, 2013 | 2003 Nissan Murano
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Sep 30, 2012 | Kenmore Elite Washing Machines
Oil leaking trans 1999 chevy S10 replaced torque converter seal leaks at front
ou may need to remove the front pump and replace the seal on the pump and the converter seal as well
Aug 08, 2012 | Cars & Trucks
I changed tranny filter and pan gasket, still leaks, possible inner seal? any suggestions?
need to identify where leak is coming from wipe clean bottom of transmission and check trans lines ,dipstick tube, rear seal ,pan for leak or drip start van and let run drive around block than park and recheck trans for leak if leak by where engine and trans meet than front seal anywhere else fix and or replace front seal two choices first can try a trans leak additive follow instructions carefully or need to pull trans to replace seal
Feb 01, 2010 | 1998 Dodge Caravan
Oil leaking in engine have replaced seal and O rings but still leaks. I am going to scream!
ok, There are many areas that the oil could leak from. Head gasket, oil pan gasket, rear main seal, front seal, valve cover gasket. You'll need to locate the leak under the car in order to know which one to replace. There is nothing simple about replacing the rear main seal and although he front seal is easier it can still be a problem. Good Luck.
Sep 04, 2009 | Ford Escort Cars & Trucks
2004 honda shadow 600 VLX leaking fork seal bike has 600 miles on it should I replace left and right if only right is leaking.
check first to see if the leaking fork has any rust pitting on the chrome,if it has and its a very small blemish then fettle it off first,and just replace the leaking seal,as the saying goes..if it aint broke dont fix it,if the seals had been in the forks for years and the bike not used then consider replacing both..
Jun 05, 2009 | 1986 Honda VT 1100 C
Rear main seal leaks..does this affect transmission??
A leaking rear main seal will not cause your transmission to leak.
The transmission has its own seal and should not leak because of the engine rear main seal.
Due to the labor involved in replacing the rear main seal on the engine, it is best if you replace the front transmission seal at the same time if possible.
Installation varies on different vehicles but the principles are the same.
Apr 15, 2009 | 1997 Oldsmobile Regency
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Peerless Industries Peerless& Single Handle Tub & Shower Faucet  Logo
800 people viewed this question
Top Peerless Industries Home Experts
Joe Lamb
Joe Lamb
john h
Steve Wood Plumbing...
Level 1 Expert
Are you a Peerless Industries Home Expert? Answer questions, earn points and help others
