Question about Sewing Machines
I need the part that holds the needle in place.It is a Brother,21
I need the part that holds the needle in place. Gr.graechaniced on the machine!
  • yadayada
    yadayada May 11, 2010
    we are not a parts service
    Brigadier General:
  • 8,619 Answers
Hi!
You can buy the Brother Sewing Machine accessories on line from the following links—
Link 1
Link 2
Link 3
Link 4
You can contact the above mentioned linked, compare prices and order for the part you needed.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 30, 2009
How do I replace my twin needles on my brother overlock 1334 D ?
That is not a twin needle. It is actually two individual needles that are separate. (There are actually some stitches that you would use only one needle, ie hem.)
The manual will have instructions on how to replace the needles. There appears to a hex screw immediately above the needles that is used to remove or secure the needles. With the hex tool included with your machine, loosen that set screw (be careful because both needles will become loose and can drop down into the machine). Hold the needle(s) with the flat side facing the back of the machine, slip them all the way up in the needle holes, hold them in place while tightening the hex screw. Be Careful to not lose the hex screw that hold the needle or drop the screw or needle down into the machine.
User Guide Manuals 1334D Australia Brother
Nov 12, 2016 | Brother Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
My button needle won't release the needle
I think you should consider a little oil if it's metal parts - it is a small spring that holds the needle in place
Aug 29, 2014 | Brother PE-770 Embroidery Machine
HI I HAVE A BROTHER XL-5011, the clamp that holds needle in place fell off whilst sewing now it won;t stay on thnxs
needs a new needle clamp screw & possibly the needle clamp too
try sewingpartsonline.com
Jan 11, 2011 | Brother Sewing Machines
What instructions are there for a brother nx400 even-feed foot
Remove the screw holding the regular presser foot and the presser foot holder and set aside.
Place the take-up lever in the highest position.
Hold the even feed foot with your right hand with your thumb holding the lever of the foot in its highest position. Place the even feed foot on the presser bar and make sure that the lever of the foot rests upon the needle bar thumbscrew. While holding it in place, fasten the foot to the presser bar with the screw.
As the needle bar goes up and down, the lever on the even feed foot should rest on the needle bar needle serew and go up and down as well.
Jul 19, 2009 | Brother Sewing Machines
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
Needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Nov 29, 2007 | Brother Sewing Machines
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
