Question about Dymo DateMark Date/Time Stamper
P reset keeps flashing and won't print
I have changed all the batteries in my DYMO datemark and p.reset keeps flashing and the unit won't print. Please help!
Open the battery compartment and use a paperclip to push the printer reset button
Posted on Dec 07, 2009
Hello, I work for the Math department here at Portland Community College. Our little datemark is flashing p.reset and we don't know why. (My boss is downloading the manual but I am trying you). We put...
Please try the following:
  1. Remove all the batteries including the 3v lithium battery. In the 3v lithium battery compartment you will see a metal tab. Bend this metal tab upward slightly to ensure good contact with the lithium battery.
  2. With the batteries out, turn the unit over so you can see the print ribbon. At one end of the print ribbon you will see a plastic bracket. This plastic bracket should move freely. Using a pen or pencil point, gently move the plastic bracket from side to side in order to ensure it's able to move freely on the print ribbon.
  3. Check the display and make sure it is completely blank. Replace all of the batteries.
  4. Press the P-Reset button with a pen/pencil point or a straightened paper clip.
Hope this help, if it does please rate my help. Thanks
Nov 02, 2010 | Dymo DateMark Date/Time Stamper
My dymo datemark stamp says "reset" but we have no idea how to do it?
Take off the back cover and insert the tip of a pen or paper clip in the little button between the 3.0 volt battery door and the AA batteries. It is "printer reset" around the little hole. This should work. It works unless something is wrong with the ribbon of letters that can get stuck. I'm trying right now to get my to reset using this solution (that has worked previously) but it is not. So it is a **** shoot!
Jan 28, 2010 | Dymo DateMark Date/Time Stamper
How does it print? (Datemark) Some magical way?
Hi Patricia,
First, try doing sequence power cycle by turning off the printer, computer and the router (if you're using one attached to your system) to make sure everything works perfectly in the printing process. Moreover, you may try to open the back cover where the batteries are and press the pinter reset button to refresh the printer settings. best regards, Jazerblue
Aug 24, 2009 | Dymo DateMark Date/Time Stamper
DYMO DateMark has P.Reset flashing, how do I reset?
Jul 08, 2009 | Office Equipment & Supplies
How quickly do the AA batteries run down in the DYMO Datemark. I just started using a new one this morning and have stamped maybe 50 times and have now received the flashing p.reset
Mine usually last at least 6 months. But I am careful to lean it back slightly to make sure It's not touching the switch on the bottom, and I only use fresh energizer batteries.
Jul 02, 2009 | Dymo DateMark Date/Time Stamper
Date/time stamper will not print correctly
mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
Jun 18, 2009 | Dymo DateMark Date/Time Stamper
Dymo datemark
Oct 21, 2008 | Dymo DateMark Date/Time Stamper
My Dymo DateMark won't print.
Feb 20, 2008 | Dymo DateMark Date/Time Stamper
Dymo DateMark stamper doesn't print.
if it is an older model [2001 or so] you just gently put your hand over the top like your going to pick it up but just push down and slightly forward. there is a button on the underside.
Jan 25, 2008 | Dymo DateMark Date/Time Stamper
1,363 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
