Question about Lindhaus Activa 30-38 Bagged Upright Vacuum
I have lindhaus activa 30. It was clogged and then cleared of the clog. When the power button is pushed, both red and green lights come on and the green turn off immediately. But no motor....
  • 75 Answers
Motor might be burnt up from the clog.
Posted on Jun 30, 2009
Why does lindhause Activa 30 hose on vacuum comes off
My hose comes off as well. It gets 'unscrewed' over time using it. Simply screw it back in counterclockwise...
Sep 01, 2014 | Lindhaus Activa 30-38 Bagged Upright...
The suction comes on but the motor doesnt turn the beater bar nor does the red or green light come on
check to make sure power is coming from wall with a voltage meter, if not wiring issue or blown motor or wiring around beater motor
Feb 28, 2014 | Lindhaus Vacuums
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
I have no suction on the Lindhause healthcare pro Hepa
Make sure that the on switch is in the upright position. Down won't give you give you suction when vacuming.
Make sure that the hose is securly in the lower part of the vacuum.
Test the hose with your hand before you put it back to see if you're getting air sucked in through hose. If not it must be clogged up somewhere. You might contact Lindhause home base.
Feb 23, 2009 | Lindhaus Healthcare Pro 14 Bagged Upright...
Getting the vacuum to start after replacing the bag
Behind the door and above where the bag is located there should be a piece of plastic, or metal that sticks out, at least in the manual, if the door isn't shut correctly, that piece doesn't push in the switch that is behind there, this is a safety feature built into a lot of vacuums, to keep people from running the vacuum without a bag in it. Most likely your lid just didn't shut completely. Check for that, and get back to me.
Jan 20, 2009 | Lindhaus Activa 30-38 Bagged Upright...
Convertable?
It is a vacuum, you would have to consult where you purchased it, they should know what you add to it.
Mar 16, 2008 | Lindhaus Activa 30-38 Bagged Upright...
SEBO air belt K
You probably have a clog either in the hose, wand or the inlet down by the brush roll. Unhook the hose from the want and see if you have suction there and if the light stays off. Disconnect the wnd and look down thru it to make sure it is clear. If there is no obstruction, then the circuit board has a problem. But I would suspect a clog.
Feb 10, 2008 | Sebo Air Belt C2.1 Bagged Canister Vacuum
Lindhaus Activa 30 EOS Version
Check the inlet by the brush roll for a clog, also check your hose for a clog. Usually when there is a clog, it is sensing an overfull bag and will shut down to protect the motor. If there are no clogs, then there could be a problem with the circuit board or motor.
Jan 01, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Activa 30-38 Bagged Upright Vacuum Logo
294 people viewed this question
Top Lindhaus Vacuums Experts
vince
ray gallant
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
