Question about 2K Games Lost Treasures of Alexandria for Windows
So. Am location must redo chamber 7 if i can't solve chamber 8
Help, I am stuck at chamber 8 and when my exasperation sets in I can't save and must redo chamber 7. I am running Windows Vista, which hasn't been a problem for any other games. Is it a problem with the game itself - The Lost Treasures of Alexandria. BTW I'm 59
To beat chamber 8 you need to use the element rocks. Make sure you have 2000 points before you start. First use the earth element rock to wipe out most of the dark brown rocks. Second go to the bottom row and use the same rock to turn the bottom row into the silver balls. They are worth extra points. Then use the rock one more time to get a 4 match of the purple spheres. Then match as fast as you can. I made it with 20 seconds to spare.
Posted on Dec 26, 2009
No internet access but connected - windows 8 pro 32bit
DHCP controls this process. What are the DHCP settings?
Mar 17, 2017 | Computers & Internet
Our Silvia, almost 8 years old, is putting out shots too fast (10 to 15 seconds), even though we've been dialing down the grind on Rocky more fine, putting more coffee in, and tamping harder. We...
Try to redo what you have been doing, but set it to the extremes to see if everything is functioning. If you set the grind say to 4, it should come out very slow or maybe not at all.
Jul 11, 2011 | Rancilio Silvia Espresso Machine
Car will not start put distributor in the car
If the dist was removed it has to be put back into the same location-to redo it, remove the dist and crank the engine around to #1 TDC (timing marks on crankshaft pulley, you can use a socket on the crank nut to rotate it)-get it dead-on and install the distributor back, observing the location of where the distributor rotor is point-that is where your #1 wire will go on the tower. Firing order on a GM is
1-8-4-3-6-5-7-2
Here is a general page that can help also
Dec 25, 2010 | Chevrolet Caprice Classic Cars & Trucks
Locate heater hose in a 2000 ford expedition
Expedition and Navigator
Fig. 7 Remove the A/C plenum demister screw and remove the A/C plenum demister adapter
Fig. 8 Disconnect the vacuum line
Fig. 9 Remove the heater core bracket
Fig. 10 Remove the 13 retaining screws and remove the plenum chamber top
Fig. 11 Remove the heater core
  1. Disconnect the battery ground cable.
  2. Drain and recycle the engine coolant.
CAUTION Never open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
  1. Remove the instrument panel. Refer to .
  2. If equipped with the 5.4L 4V engine, remove the junction block splash shield.
  3. If equipped with the 5.4L 4V engine, remove the bolts and disconnect the cable ends from the starter relay.
  4. If equipped with the 5.4L 4V engine, remove the junction block bracket.
  5. Disconnect the heater core hose couplings.
  6. Remove the retaining screw and remove the A/C plenum demister adapter.
  7. Disconnect the vacuum line from the A/C plenum demister adapter.
  8. Remove the heater core bracket.
  9. Remove the 13 plenum chamber top retaining screws.
  10. Remove the plenum chamber top.
  11. Remove the blend door assembly from the case.
  12. Remove the heater core.To install:
  13. The installation is the reverse of the removal.
Also this VIDEO can help to solve your problem...
Hope this help.
Apr 26, 2010 | 2000 Ford Expedition
Ignition Distributor location
There is no cap and rotor, as the vehicles igntion system is DIS (digital ignition system). The recommended tune-up on these motors require sparkplug and coil replacement. The coil type in this vehicle is COPs (coil over plugs). Usually moist and oxidation develope on the sparkplug chamber walls from faulty or worn coil boots. This causes the coil to short, they must be replaced at 75,000 miles at the same time the sparkplugs are replaced. Typical symtoms are: Vehicle stalls (restarts and runs normal), intermitted jerks/sputter while driving, misfires, rough idle, severe power loss. Hopefully this helps
Sep 01, 2009 | 1997 Ford Expedition
Bm netvista 6843 desktop change bios language
Courtesy of the Fixya Tech.....
sandrew
Two options:
Take the side panel off,then :
You will have to locate the 'JBAT1' terminal and move jumper from pins 1-2 to pins 2-3 then back to pins 1-2, to reset bios.
Or Go into BIOS and set it to defaults:
For solving the problem do the following:
1. Switch on the system
2. Press and hold the Del or F2 key to enter into BIOS
3. Select the default load settings
4. Save it by pressing the F10
5. Restart the system
6. Select the safe mode by pressing the F5
7. Select the restore point on the date which the settings had been changed.
8. Save to the point
9. Restart the system by normal mode
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | IBM NetVista PC Desktop
Need a air brake diagram for a Ford L7000
96 F & B Series
Air Brake System, FT Series
Item Part Number Description 1 2025 Front Brake Chamber 2 2A095 Quick Release Valve 3 2075 Compressor 4 2085 Governor 5 2A783 Tank Valve 6 2A550 Safety Valve 7 2063 Air Tank Reservoir 8 2A567 Drain **** 9 2B170 Single Check Valve 10 2K119 Double Check Valve 11 18737 Low Pressure Indicator 12 2A270 Foot Control Valve (E-7) 13 13480 Stoplamp Switch 14 2A662 Parking Brake Control Valve (PP-1) 15 2B280 Chassis Bulkhead Manifold 16 2B431 Inverting Relay Valve (R-7) 17 2A449 Relay Valve (R-12) 18 2225 Rear Brake Chamber A — 3/8-Inch Hose B — 1/4-Inch Hose C — 1/2-Inch Hose D — 5/8-Inch Hose
May 04, 2009 | Ford F Cars & Trucks
Unable to change settings on Microsoft Lifecam VX-1000
uninstall then redo but make sure no folder in program files afer uninstall
Jan 08, 2009 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
2K Games Lost Treasures of Alexandria for Windows Logo
151 people viewed this question
Top 2K Games Video Game Consoles & Games Experts
Dave
rhodesworks
Are you a 2K Games Video Game Console and Game Expert? Answer questions, earn points and help others
