I turned the AC off at the breaker box and now the AC won't come back on.
  • FunnyPlumber
    FunnyPlumber May 11, 2010
    Did you turn the breaker back on? Did you turn the thermostat to "cool" and the temperature to below the temperature in the thermostat area? Did you wait ten (10) minutes after you did settings?
  • 148 Answers
Thermostsat is calling for a/c
switch outside is on
air handler switch is on or furnace switch
emergency switch to furnace or on the side of unit
cause if the coil is on the furnace it uses the same blower that is why i am asking
Posted on Jun 30, 2009
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
What will stop the fan to stop spinning on a goodman ac unit on the outside
If you are wanting to just get it to cut off because it won't do it on it's own, you can turn the a/c breaker off at the breaker box. I have seen alot of blower fan switches go out on older goodman units and the blower stays running all of the time. Get a technician to check it for you. Good luck .
Jun 18, 2011 | Heating & Cooling
I accidentally plugged my wii into a 220 volts.. it won't turn on.. Where is the problem? Is it in the ac adapter or in the console itself? Oh no. please help me. I'm not sure if i should buy an ac...
wow that sucks, try going to gamestop in the morning and getting either a new or refurb/used one for about $20. hopefully you just blew the ac adapter and not the wii. also check to make sure you didnt trip the breaker the wii is on (check the breaker box/s around the house).
May 21, 2011 | Nintendo The Biggest Loser for Wii
How do I turn on the circuit breaker on my goodman ac? The smarter Tec flipped the circuit breaker. Do I turn it or push it?
If it is the breaker box in your house, then just push it to the side so it is lined up with the other breakers in the box. Actually any breaker will be like that. If it is the disconnect outside then it pulls out and you flip it over and put it back in.
Sep 02, 2010 | Goodman CKL49AR49 Air Conditioner
Goodman ac unit won't come on at all
ALSO CHECK FUSES IN BOX ON OUTSIDE WALL . SHUT OFF BREAKER BEFORE FUSE CHECK. BREAKER MUST BE TURNED ALL THE WAY OFF THEN BACK ON TO RESET
Apr 20, 2010 | Goodman CLQ36AR49 Air Conditioner
My ac thermidistat control box is out how can i turn it back on i drain the out side pipe and the box won't turn on i check the fuse box and it's on
t stat is bad jump t stat red white yellow wires tie together will start ac if it works t stat is bad .shut breaker off first for air handler .Run to test untie wires when done.
Dec 15, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
