Question about Garden
Need to replace gas line inside mcculloch chain
I need to replace gas line inside mcculloch chain saw gas tank. The original neoprene line disingrated & I don't know where to or how to install a replacement line.
McCulloch Model 3214
    Brigadier General:
  • 4,088 Answers
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
How do you replace the fule lines that goes inside the gas tank on a poulan 445 pro
A replacement kit typically includes instructions. Otherwise check your service manual or search Youtube.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Dec 16, 2013 | McCulloch 10" Electric Pole / Chain Saw
Gas line fell apart inside the fuel tank how do i get the gas tank off to replace the line
The motor and the tank are held together by a rubber mounts or springs which helps prevent engine vibration from going to the handles. These mounts can be unscrewed to allow the separation of the tank from the motor. They are called anti-vibration mounts and should be on your parts list in your owner's manual or on the manufacturers website.
Oct 03, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have an older model Mac 4600 18" chain
Go to Mcculloch.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 27, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
McCulloch chain saw
check the plastic tubbing in the gas tank might need to be replaced or the primmer bulb has a pinhole in it.
Jun 21, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel line in gas tank broke how can I replace ? MCCULLOCH CHAIN SAW MODEL NO 3200
An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
A typical fuel system and a couple of suggestions follow (on this saw LOTS of photos):
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | McCulloch Garden
Need Gas Line installation instructions for a McCulloch Lawn Trimmer I bought New Neoprene tubing (Gas line) for My McCulloch trimmer model B400128-11. The old lines hardened over the years, and broke off...
Hi Start from the filter in the tank to the bottom of the carby then from the top of the carby to the short primer pipe then from the long pipe on the primer back to the tank. Hope this helps.
Aug 24, 2009 | Garden
I need a repair manual for a McCullough gas, 35 chain saw
Mc chain saw fuel lines rotted away need to know where they go
How the primer lines go! There are 2 outlets on carb. two tank lines two primer lines
Jan 11, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Loose Fuel Line In the Gas Tank
hi rhopdo
try to find the spark plug near the muffler(exhaust)
check where is the hole from the gas tank, connect the fuel line to the carb.
yours savumihai71
Dec 01, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
732 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
