Question about HP PSC 1610 All-In-One InkJet Printer
HP 1610 All In One noise
We have an HP 1610 All in One Printer - It prints fine, but when the first sheet of paper comes thru it sounds like a rivet gun is being fired...it also makes this noise when I open the cover to see if I can see the problem. the printer is a 3 years old and has always worked...works now, but just makes the noise as described
  • 10,515 Answers
There is a troubleshoot document prepared by Hp for it's customer's.Follow the below guidelines and you would be able to fix this issue :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd07280&lc=en&cc=us&dlc=en&product=59211
Any further help, let me know.
Thanks for using "Fixya".
Posted on Jul 02, 2009
  • 51 Answers
Since your printer is 3 yrs old ..just give it for a service and ensure its catridges and other part are dust free
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
Prints a information sheet after every print i do how do i stop ?
Go to printer under control panel and view properties for that printer, click anything that says default settings.
Is this on one document and application only. Is it the print settings of the document?
Nov 17, 2009 | HP PSC 1610 All-In-One InkJet Printer
I only get a black sheet of paper if I copy with my hp 1610
you will need to download the driver for leopard after you remove tiger
Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
Making a loud noise when the paper is feeding.
This is what the HP website says about noises in the 1610..
Issue Unexpected noise (clicking, thumping, grinding, squealing, and so forth) from an HP all-in-one can be caused by a problem with the ink carriage or the scanner. Solution Follow the steps below in the order presented to determine the source and resolution for the noise. Step one: Checking the scanner This step applies only to products equipped with a flatbed scanner.
  1. Open the scanner cover.
  2. With the lid open, press the Start Copy button to make a copy. The scanner mechanism should move down the glass.
  3. If the scanner mechanism does not move and noise is present, contact HP. If the scanner mechanism moves without noise, continue with Step two below.
Step two: Checking for paper feed problems and carriage blocks Click here (buu03110) (in English) for more information on paper or carriage jams. Step three: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. So it sounds like it needs to be serviced which could get expensive. I've looked all over the web for you & Keep finding the same answer. Sorry I can't come up with a better solution for you.
Nov 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1610 "clunks when starting print job"
There are a number of potential causes and solutions to this sort of issue. They all seem to be hardware related, but HP.com has a web page with links to solutions that may apply to your situation:
Unexpected Noises when Printing
Hope this helps. Good luck.
Aug 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
Doesn't print!
u sure litte thing on new ink is off platci cover that protects them download the latest driver ok from kodak website try it again thx nick
Jun 16, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1610 All-In-One InkJet Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
