Question about HP OfficeJet 6110 All-In-One InkJet Printer
Mac OS 10.5 Leopard
Since upgrading OS to Leopard the HP Scan Pro software crashed. I reinstalled and not get message that it can not find the scanner. It prints fine.
  • 9 more comments
  • koning Nov 20, 2007
    leopard tells me a driver is missing if i want to scan; printing is ok.
  • JonMack Nov 28, 2007
    My HP office jet prints but cannot scan after i installed leopard.
    The PC side, bootcamp, has the same problem.
    Before the leopard download, the scanner worked perfect.
    So did the PC side of my mac.
  • Anonymous Dec 06, 2007
    Loaded Leopard the other day and tried to scan today.  Same problem.
    Looked for updated driver and found none.  I guess I'll just wait.
  • duncank Jan 02, 2008
    Also experiencing the same problem with leopard upgrade and the scanning software which has since stopped working.  Have tried reinstalling the original driver, but no go.  If there's anyone out there with the solution, to this problem you can get hold of me at
  • SKjunkMAIL Jul 28, 2008
    I have Mac OSX 10.5.4 (Leopard) installed and can no longer scan either. I have a C6180 Al-In-One InkJet and can not find a solution.
  • jonbob Sep 01, 2008
    My new Mac with Leopard 10.5 will not allow me to scan - printing and faxing are OK.  Went to Apple store and was advised to reinstall driver from disc but this did not help - when I try to open scanning, it freezes and says there is no scanner attached.
  • funkart Sep 10, 2008
  • Remley_L Sep 17, 2008
    After installing OS 10.5 the scanner on my 6110 will not work. Fax and printer are fine. I called HP. They told me they have no intention of providing an update for this particular model and Leopard. They told me to purchase a new scanner or another all in one.
  • bofh Dec 31, 2008
    Maybe I'm being dense but how do you force the 6110 to use the 9.7.1 software?
    I download and installed the dmg but when I start the All-In-One Device Chooser, I do not see my 6110 listed. Do I have to restart/unplug or something?
  • Anonymous Jan 05, 2009
    I have the C6180. It appears that the problem occurs when I update the HP software to v.1.1.1  When I keep the version below that I do not have a problem. The moment I install the 1.1.1 software then I can no longer scan.
    My solution is stay away from 1.1.1
  • Anonymous Feb 11, 2009
    Yep! Me too. Always comes up with a "Sorry, Scanner could not be initialized" message. :(
I was able to get my 6110 to scan by downloading HP_Installer_PSC7100_v9.7beta.dmg .  I saw this on XLR8YourMac for another HP multi-function and on a lark I decided to try it.  During the installer it won't detect the 6110, but you are able to "Skip" to the next step until it's installed.  Then, launch "HP All-in-One Device Chooser" and you will see the 6110 listed.  After I choose it there, I was able to use "HP Scan Pro" with the 6110.  I've not really tested the rest of the applications.
Posted on Feb 02, 2008
  • JJTX77 Jan 05, 2009
         My last solution was somewhat incomplete.  It worked with my last system (Dual G5 under 10.5) because at some point I had loaded an older version of the drivers and "upgraded" them.  I tried my own solution since switching to a IMac 20" (Intel) with 10.5.5 and it didn't work.  I'm guessing this is because loading the original drivers install some profiles for the 6100 that are not loaded by drivers intended for other models. So, I tried a few things and I am pretty sure what got it working was loading "6100_790_EN.dmg" then loading "HP_Installer_OJ6200_v9.7.dmg".  The "6100_790_EN.dmg" install had an unexpected quit for 'HPIO Trap Monitor' but I was able to carry on.  The 'HP Setup Assistant' launched after the 790 driver was complete, but it did not find my 6110 so I quit it.  Then, I ran the OJ6200 installer.  I chose "My device is not listed" to enable the "Continue" button.  Then on the next page of the installer I choose "Officejet 6200 series".  After the files copy the next page choose "Skip Setup" and unchecked the "Remind me to run the Setup Assistant..." and "Add the Setup Assistant to the Dock"  and clicked "Skip".  Finally I got the big green check and "OK" to exit.  Then I run the 'HP All-in-One Device Chooser' and my 6100 is now listed with it's serial number.  I choose it and "OK".  I launch 'HP Scan Pro' and do a "New Scan" and yay it's working!  I can't guarantee these steps but perhaps they will help someone out there.  I am not going to be buying another HP printer.  As far as I can tell the reason it doesn't work is because they don't include it's profile in the newer drivers.  Seems like a intentional omission the "encourage" an upgrade!
I just downloaded the latest driver from the HP website: HP_Installer_PSC6100_v9.7.1.dmg
Go to HP Customer Care > HP Photosmart C6180 All-in-One Printer > Mac OS X > Software & Driver downloads.
It works fine for me now.
Posted on Feb 06, 2009
The issue is that the scanning software works fine as long as you leave it in place when upgrading to Leopard.  If it gets damaged in Leopard or for whatever reason needs to be re-installed, your out of luck.
Why?  Because HP has not released something as simple as a NEW INSTALLER for the software.  The installer that is on the HP website now basically hangs during installation.
Now, if anybody new how to manually install the stuff in the right places, that could solve the problem.  But so far I haven't seen anything about how to do that.
BTW, it has been well over 60 days since Leopard came out and HP still hasn't come out with new software.  It's pretty clear that they want you to buy a newer unit.
I won't.  I'll be voting against an HP with my pocketbook.
Posted on Jan 30, 2008
In Snow Leopard, open Image Capture, wait for your printer to show up, and scan from there. You can even feed multiple pages through the document feeder and scan into a single PDF!
Posted on Oct 30, 2009
  • 28 Answers
Fiend your solution direct from hp. Here is your solution...
Posted on Feb 28, 2009
The link above has changed to:
Posted on Sep 17, 2008
I have this problem as well. I fixed it by downloading and installing the HP drivers for os 10.2.8
Posted on Mar 03, 2008
HP Officejet Full Feature Software and Drivers - Mac OS X v10.3.9, v10.4 and v10.5HP Officejet 6210 All-in-One Printer/Fax/Scanner/Copier
Posted on Feb 24, 2008
I too have encountered the loss of the scan function in my Hp 6110 after upgrading to Leopard. The following quote is the response that I received from Hp Total Care. What "further assistance" could she be suggesting?
"Thank you for contacting HP Total Care.
There are no full feature drivers available for the Macintosh OS 10.5 that is compatible with the Officejet 6110. The engineers will not be creating any full feature drivers for the
Officejet 6110. You should have print functionality because of the built in drivers, but you will not have scanning functionality.
If you need further assistance, please reply to this message and we will be happy to assist you further."
Posted on Feb 05, 2008
Apparently HP have still to update drivers for many All-in-ones. The 6110 officejet seems to be one of those. The website says we'll have to wait from 50-60 days.... (I hope that's from Leopard's release date.)
Posted on Dec 05, 2007
HP moved the file to here:
I tested this and it works!
Upgrade to Leopard 10.5.2 Download VueScan (there's a free trial but the full version costs $40)
This is the only way I've found to make this work, but it does scan now just fine
Posted on Mar 14, 2008
I cannot scan with Leopard etiher
Posted on Sep 16, 2008
  • HP Master
  • 1,113 Answers
Download and install correct driver and software package to suit.
print driver and scanner software are not the same thing, sounds like you have right print driver but wrong scanner software and driver, goto HP and download
Posted on Nov 08, 2007
Hi Bobby
You will need to get an OS X installation DVD. Try eBay.Don't go for anything lower than 10.4 (Tiger)10.5 (Leopard) and 10.6 (Snow Leopard) should run fine on this machine.Don't bother with 10.7 or 10.8
Jan 05, 2013 | Apple PowerBook G4 Mac Notebook
How do I upgrade to 10.5 or .6?
Firstly you will need to buy a copy of 10.6. This is available from Apple (see link below) or you could get a copy from eBay.
Mac OS 10 6 Snow Leopard
The following article will tell you what to do next:
An Easy Guide to Installing Basic Upgrades in OS Snow Leopard 10 6
May 29, 2012 | Apple Mac OS X 10.4
HP Photosmart C3180 All-in-One printer, Scanner, Copier will not scan with Mac OS 10.4. The button flashes for a few seconds, then stops and nothing happens. No image appears on my computer screen.
All lot of those printers came with two separate driver's disc. Make sure that you are installing the correct for the mac and not windows. If you are you can go to the hp website and do a search on there website for the driver for mac operating system.
Apr 25, 2011 | HP Photosmart C3180 All-In-One InkJet...
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I have a new imac running snow leopard. When I try and scan it says unknown error occurred.
Make sure you have upraded to OS X 10.6.2 then download HP printer drivers for Mac OS X v 10.6.2 2.3 from Apple - Downloads - Firmware & Hardware - HP printer drivers for Mac OS X v 10.6.2 It worked for me.
Jan 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a Mac w/Snow Leopard. I cannot get to\support to download drivers for an Office Jet 7780. The Mac recognizes it as a printer but not as a scanner.
As from this link , the drivers for most HP printers are already built-in to Snow Leopard. Thus, they didn't recommend reinstalling driver from your HP printer CD. Here are some excerpts regarding scanning feature on Snow Leopard from the link: Scanning: The Scanning interface is now built into Snow Leopard and supported with the Apple Image Capture application. Instructions follow. NOTE: HP Scan Pro software (from Mac OS X 10.4, 10.5) is not supported in Snow Leopard. The HP icon for HP Device Manager still in the dock after upgrade is not functional and should be removed. NOTE: Scan support from pushing the Scan button on the printer is not supported with this version of the scan interface built into Snow Leopard. Scan functionality is supported by scanning directly from the computer.
** there are methods on how you can scan on Snow Leopard from the link that I've given above. But I'll paste here Method 3:
Method three: Scan from Print & Fax > Printer browser
  1. From the Apple menu, choose System Preferences .
  2. Click Print & Fax .
  3. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  4. Click the Scan tab, and then click Open Scanner . The Printer Browser window appears.
  5. Click the Scan icon at top right of the toolbar to launch scanning. The scan interface opens. Click Show Details to view settings and options.
Important Gotcha: If the Scan or Print icons do not appear in the Printer Browser window toolbar, you need to delete the current HP printer queue and add a new one, as follows:
  1. Close the Printer Browser window to return to the Print & Fax preference pane. Or, go directly to the System Preferences > Print & Fax pane.
  2. Select your HP printer in the list on the left.
  3. Click the - sign at the bottom of the list to delete the product from the list.
  4. Click the + sign at the bottom of the list to add the product back to the list.
  5. Select your HP printer, and then click Add to create a new print queue. The next time you open thePrinter Browser window, the Print and Scan icons should appear in the toolbar, providing access to Image Capture.
Oct 22, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP C4580 scan and Snow Leopard
Heads up..
HP Scanner software (ex. HP device manager, HP Scan Pro) no longer works in Snow Leopard OS since it's already preloaded. There are three methods for you to scan.
1. Preview
2.Image Capture
2.Scan under Print and Fax
Sep 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
HP PSC 1315, scanner and Mac os
To scan documents on Mac OS X using your HP PSC 1315, you need to download HP's "Device Manager" software which is available here :
I just installed the software and am now scanning problem-free.
Oct 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner won't operate on HP PSC1410 All in one with Leopard
Hi, as per HP's support page on this product here
It seems that there aren't any drivers compatible with Leopard for this printer at the moment. The latest OS supported is Mac OS X Tiger... You will have to wait untill HP do something for leopard...
Mar 07, 2008 | HP Officejet J5780 All-In-One InkJet...
HP ScanJet 7650 asking for DPE
This problem happened to me to (OfficeJet 6310xi). These steps solved my problem:
When the program has the error, there's a button so you can show it where DPE is. Click the button
Navigate to Macintosh HD/Library/Application Support/Hewlett-Packard/HP Scan Pro/DPE/
Click on DPE
Then I could scan to pdf. When I upgraded to Leopard, I reinstalled my HP software, even though HP says it isn't totally compatible with leopard.
Nov 04, 2007 | HP ScanJet 7650 Flatbed Scanner
HP OfficeJet 6110 All-In-One InkJet Printer Logo
10,512 people viewed this question
Ben Johnson
