Question about GE Refrigerators
What causes water to run in bottom of refrigarator
  • 370 Answers
This is caused by plugged drain tube. When the freezer goes through a defrost cycle the water drains down a tube in the back of the freezer to the pan under the refrigerator. When this tube is plugged the water doesnt drain through the tube but drains through the vent in the refer. The easy way to fix this is to unplug the refrigerator for 24 hours.
Posted on Jun 30, 2009
Amana frige freezer only cool not cold what could be the problem
check ur settings on the air flow control knob and the cold control knob? are they both set to high? are the door seals working ok no air leaks. is the fan running? l;astly check the thermistors?
Mar 09, 2015 | Amana Refrigerators
Refrigarator leaking inside
Most freezers have a drain tube behind the back panel. To drain water from defrost mode. This tube freezes up and won't drain. Causing water to drip in the refrigerator making a mess on the shelf. Remove the bottom plate of the freezer remove the back plate. There is a piece of aluminum with a whole towards the middle this is the top of the frozen drain use a turkey baster and hot water to thaw this line out when it is thawed the water will run down into a tray under the fridge. no need to dump it it will evaporate. But you can pull it out to make sure you're hot water is going all the way down. I hope this is helpful.
Apr 03, 2013 | Refrigerators
Hi my refrigarator is not cold lost fridge temp
I have the same fridge its the sensors there hidden behind the back panel. there are 2. one at top and one at bottom. one of them will faulty. there cheap to buy and easy to fit.11_16_2012_11_30_22_pm.jpg
Nov 16, 2012 | Samsung RS2630SH Side by Side Refrigerator
Freezer has alot of frost build up and the refrigarator has water leaking and running under vegetable trays in bottom and freezing what could be wrong It is a whirlpool top freezer 21 cubic ft and is 2...
Hi, this sounds like a problem with a blocked defrost drain. For full instructions on clearing the drain from my tips click HERE . If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My Refrigarator and freezer are not working, Its not cold enpough
Hello, this could be a thermostat or gas problem. If the motor is running fine then I think that your fridge may need regassing. You will have to call a repair man in to help, I hope this helps.
Nov 07, 2009 | Hotpoint (HSM25IFTSA) Side by Side...
MY REFRIGARATOR IS LIQUING WATER ON THE FREZER COMPARMENT AT THE BOTTOM MAKING A BIG PIECE OF ICE NOW I HAVE PROBLEM TO CLOSED THE DOOR
Probably the drain hole inside the freezer in the bottom back wall is clogh,put hot water in it until melt the ice and keep putting hot water to make sure it goes through.When the drain is clogh the defrost water goes down to the freezer floor and freezes up and the drawer stick to the ice.
Jul 13, 2009 | Refrigerators
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
