Question about Microsoft Xbox 360 Console
My xbox overheats every few minutes. ive tried intercoolers, laptop fans. ive waited a few days to play it. i cant do anything on it or it willl overheat.
    Filmmaker:
    Uploaded 5 video answers.
  • 182 Answers
HERE TRY THIS I DID THIS VIDEO ON YOUTUBE AND IT NOT OVER HEATING. IF UR XBOX360 IS NOT ABLE COME BACK AND U ONLY GET THE 3 LIGHTS STOP THE FANS FROM SPINING TILL TWO RED LIGHTS TURN ON THEN DISCONECTED FOR 20 MINUTES BUT TRY THAT MOD I DID ON MINE TOO AND LET ME KNOW IT IT HELPED A LITTLE HOPE THIS HELPS A LITTLE
http://www.youtube.com/watch?v=BDEL3orLGq8
Posted on Jun 30, 2009
Ok so i have a problem with my xbox 360 slim i recently bought call of duty ghosts and i played it for about a month about two to three hours a night three to five nights a week recently ive tried playing...
Try blasting some compressed air inside near the fan (when the console is off and cool) If not, there is either something lodged pretty good in the fan or the fan is failing. Both would require you or someone to open the 360. Cheap fix though, considering the overheating hasn't taken too much of a toll on the hardware.
Mar 21, 2014 | Video Game Consoles & Games
Ps3 overheat
Your PS3 might have a broken fan. If you are using an external fan that attaches to the PS3 than stop, fans like the Nyko Intercooler and Pelican cause more problems with ventillation and may cause the PS3 to overheat. If heat is an issue make sure the system has plenty of room to breath and point a small fan at the console. If thiat doesn't work call Sony customer sopport.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 halo problems
my halo sometimes does the same thing when i start up the game but pressing a usually gets you through it, but if your xbox 360 overheats within minutes and is an older xbox 360 its usually a burnt out fan or just full of dust, if its old then ur warranty might already be out and if it is just open up the xbox and use an air compressor or anything else to get all the dust out of the xbox. in my case everything was just caked with dust. anyways... good luck
-Armand M.
Jul 24, 2009 | Microsoft Xbox 360 Console
My xbox overheats every five minutes
i can tell you right now to by an new xbox
Jun 29, 2009 | Microsoft Xbox 360 Console
Constantly over heats even with intercooler
Try arranging the xbox vertically, if you havent already. The xbox and ps3 both were made for much better cooling when arranged in this way.
Unfortunately, if the ambient temp in your room is high, or if you live in a hot area, you may not be able to do much. Try to keep the xbox out of a cabinet or any enclosed space, and give it as much airflow as possible.
If all that fails, I would consider sending it in to Microsoft for repair.
May 04, 2009 | Microsoft Xbox 360 Pro System Console
Two red rings. only on guitar hero world tour
it probably got over heated and the solder melted or cracked. u have to send it to microsoft or take it somewhere to get it fixed
Feb 02, 2009 | Microsoft Xbox 360 Console
Two overheat rings....but only on Guitar hero world tour.
The system is suffering from overheating which caused the solder under the GPU to loose contact with some of the board. We can fix this for you. We have fixed hundreds with the same problem. We are listed on this site.
www.videogamerepairservice.com
Xbox 360 Keeps Crashing
buy a fan for your xbox 360, if it continues contact microsoft and see if they have a solution, it could be an internal problem that needs repairing, i have the same problem but i am going to get a fan which will cool the 360, and reduce the chance of my 360 breaking
Oct 20, 2008 | Microsoft Xbox 360 Console
2 left side red 1/2 ring ligts
These two lights are actually an indication of overheating. Typically this happens if the heat synch is not making good contact with the cpu or gpu, or the cooling fan is not working properly.
If the fan gets really loud just before it overheats and turns off then it is likely a heat synch issue
You can try searching for the xclamp replacement fix (I won't leave my own tutorial here as there are a plethera of them out there, just use a search engine to find them)
If the fans do not make noise - it may be that they are not working properly, you may want to replace it with another cooling fan. Talismoon fans are widely available and very quiet.
Try cleaning the console - dust and debris trapped inside the console traps heat as well.
Other than that if the console is usuable for more than a few minutes and it overheats after an hour or more, then you can try removing the heatshield (metal piece located under the top plastic cover) and or replacing the cooling fan with a more effecient fan. Please note that removing the heatshield is not recommended as it protects the top of the console from the extreme heat built up by the console, but removing it does allow for a much more significant amount of air flow.
Try and keep the console off the ground - along with the power supply
Play it horizontally instead of vertically and keep it away from carpets which trap heat and other sources of heat.
As always contact microsoft for warranty info prior to opening the console or letting someone else fix it for you.
Hope that helps.
Jul 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 taking longer to load up
Concidering that your warranty was renewed when your console went in for service, I would call microsoft and tell them of the error. Also, when they re-set your console, they made it so that you have to manually sign in.
Apr 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
307 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
