When I turn on the washer the water goes in and then stops and an E: flashes-there is no code.It sounds like the water drains out and then just beeps and flashes. It does this on every cycle.How do I get it to work?
SOURCE: Door locked,wont spin or drain.
humming noise suggests a foreign object in the pump. crack open filter and drain water into a shallow tray. repeat till empty. remove filter completely and clean it. check if something stuck in pump impellor. this should be visible by looking into the filter hole
SOURCE: Bosch Nexxt Washer Error Code E02
Check that water inlet tap is open and hose is not kinked....the error is for water inlet taking too long.... Oshie
Normal
0
false
false
false
MicrosoftInternetExplorer4
st1\:*{behavior:url(#ieooui) }
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
I had the same problem. Error code E04 with a full load of laundry and water in the washer. Unplug the power to the washer. Take off the round cover plate in the front right. Mine did not turn clockwise or counter-clockwise, it was completely stuck. Used two flat tip screwdrivers to carefully pry it away, without damaging anything. The plate is a hard plastic but just pliable enough.
Once removed, you will see the pump (img_0001). Unscrew the pump cover slowly. There will be water coming out, so be prepared. In my case we had a LOT of water, so I drained it gradually into a couple of large garbage bags. Wrap the bag opening tightly against the pump surround to minimize spills (img_0002).
Once all the water is gone, remove the pump cover and clean out any items trapped in the pump and in the drain from the drum (img_0003). In my case it was some loose change and a small ColorCatcher sheet. Reassemble the pump and you're done.
Also helpful:
http://www.fixya.com/support/t1589624-bosch_nexxt_dlx_washer_open_round_panel
img_0001
img_0002
img_0003
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: Washer stops before rinse cycle and will not open. Reads E:04
Hello and welcome to fixya.
The "E04" error code on your WFMC series Bosch washer`s refer to a drainage problem as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
What you may have is either a clogged pump, improper detergent being used, ( must use "HE"/lo-sudsing detergent ) hence suds not allowing a proper drain cycle, or wires loose at the pump...the later being the least likely.
You haven`t mentioned if you`ve checked the pump...it is likely just that, a blocked pump.
Anyway, here`s the most likely way to remedy a E04 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this indeed solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
