We're can I get a sandisk micro 4 gb usb it is comparable with a 2 camera wired colour CCTV kit cwk4
SOURCE: Micro SD 2 GB just stopped working
I had this same issue added music to my card did a safe remove from my comp. placed in phone and it stated "No memory card inserted" and wont read in adapter in computer Im so Sad i lost all my pics/memories :( it just means that the Card is Fried (Burnt Out) no way to fix this their just like SIM cards In 3G phones and if the copper bars get scratched or bent just the slightest bit it kills the SD card.
SOURCE: pc not recognizing sandisk micro sd
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
SOURCE: how to unlock micro 2 gb sandisk memory card?
I have a sd card that is locked the little switch on the side is broke off. Is there a way I can unlock my card.
SOURCE: i am not able to open the sandisk cruzer 4 and 8 GB USB
You can download the driver for Cruzer micro from below website
http://www.sandisk.com/sandisk-support/driver-download-wizard
Thanx
SOURCE: Hi, I have a Sandisk Cruze
Do you have a legit copy of windows, sometimes if the copy is (Backup) then Windows will purposely disable drivers.
If, its a genuine version, first try plugging your usb device into another usb port somewhere. Try powering down your PC and powering it back on. If these steps do not work, go to Start>Contro>Driver/Devices and look if there is any Yellow caution signs with the device plugged in. If so, click on it and follow the steps prompted to find the appropriate driver for your USB device. It will do a search by itself.
Hope this helps-
J.Sper
