Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
My heater ran for four hours then I smelled something burning and there was smole coming out of the vent...what could cause this?
  • 990 Answers
Nests inside the heater, or build up of soot on the heat exchanger. You should always have your heater serviced each year at the onset of heater season.
Posted on Dec 10, 2009
Burning plastic smell from washer dryer combo
You have something between inner and outer tub remove top cover smell coming from air vents of outer tub then that is were it is
fun job its has to come all apart
Jun 28, 2016 | LG WM3987HW Front Load Washer / Dryer
Burning plastic smell when cold out run heater and fan inside car and out
Are you loosing radiator fluid. sometimes the heater core will rupture and you will smell burn odor. also check for strange rubbing sounds or screeching coming from the blower fan motor. or engine exhaust manifolds are hot when car is on, make sure nothing is leaning on them which will cause a burn odor. Any odor coming from outside will find it's way inside through the fresh air vents.
Feb 13, 2016 | Cars & Trucks
Why when I start my car is there an odor coming from vents that smells like something is burning, and my Air Conditioner still blows, but it only blows out hot air. 2008 Chrysler Sebring. Help?
have an accredited ac shop as an ac cannot produce hot air only cold air so that means that the ac is not working (leaks low on gas etc). The hot air is from the heater in the car and the smell is probably wire overheating or the resistors are burning.
Aug 16, 2014 | 2008 Chrysler Sebring
Ran gas now starts then turns off and smells like burning rubber
Not sure I follow your story. If you really did run out of gas, you may have damaged the fuel pump in the tank. But it would not cause any smells.
Can you tell where the smell is coming from ?
Feb 19, 2014 | 1987 Oldsmobile Ciera
Smell of burning oil out of heater vents
Have you checked under the hood,Mark? The heater commonly pulls outside air thru the vents and can get air coming up from the engine,so I'd look for a smell outside the car,under the hood.Let me know what you find.
You can alleviate it some by using the recycle air button on your heater,but you need to find the source quickly,so you don't have a fire. don-ohio (:^)
Nov 19, 2011 | Cars & Trucks
MPV 2002. Black particles come out from air vents
I get the feeling this is the first time you've used the heater? Its probably accumulated dust. As long as you don't get a burning smell or smell exhaust fumes you should be ok after a few hours use.
Jan 06, 2010 | Mazda MPV Cars & Trucks
My toyostove is making the room stinks(burned dieseal ) smell. What is causing this?
Something to check would be the exhaust vent for leaking. We just replaced our old Monitor 40 because it was making some terrible exhaust smells in our house and it turned out their was a crack on the exhaust line just where it enters the stove. May be worth looking into. They are a lot cheaper than a whole unit!
Nov 30, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
247 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
