Question about Samsung Digimax S500 Digital Camera
What to do?
I put new batteries in and it just beeps 3 times and nothing else
5 Suggested Answers
SOURCE:
SOURCE: camera not working
thanks for the help but I found out the problem, the lens had gotten jarred and was stuck open,with alittle movement it solved the problem.
Posted on Feb 10, 2008
SOURCE: camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Posted on Feb 18, 2008
SOURCE: Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Posted on Aug 26, 2008
yo5bdm
  • 81 Answers
SOURCE: Put new batteries in and it does not power up
Are the batteries fully charged?
Does it work with the old batteries?
Chances are that the batteries are faulty. If they are in warranty it shouldn't be a problem replacing them with new ones.
Posted on Apr 06, 2010
How do I re-boot and old linovo R61i laptop
take the new battery out
see if it will kick start just on mains power
if you hear a beep as it powers up mother board is ok
if the mother board is dead and no beeps it wont start up
try this each time from power up
if you hear a beep hold down
one of these F5 of F1 or F 12 wait to
see if a menu from the mother board itself is visabe
then follow the prompts
if nothing also suspect hard drive or chip failure
Jun 19, 2016 | Lenovo ThinkPad R61i Laptop
My dell inspiron 1525 wont even come on when i press the start button, nothing?
Hi Jerrel Castille,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there is a Power/ Battery status light glowing near the front (touchpad) of it.
Feb 05, 2015 | Dell Computers & Internet
I just bought a new 600 va and I charged it overnight. Nothing is plugged into it and when I turn it on it beeps seven times and pauses and then beeps seven times and pause non stop. Does anyone know
Check your manual and in the troubleshooting section you will see that those beeps (# of Beeps mean something) are telling you the alarm code. Example - 2 beeps = Input Out of tolerance, 3 beeps = Frequency out of tolerance. Again these are just examples.
Jan 26, 2014 | Computers & Internet
Put new batteries in and it does not power up anymore. Beeps 3 times and nothing happens.
Apr 03, 2010 | Samsung Digimax S600 Digital Camera
I have a samsung L100 digital camera. the battery had to be recharged but the lens cover only partially closed at the time that it shut down. I tried to recharge the battery, when I turn on the power...
The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
Dec 25, 2008 | Samsung L100 Digital Camera
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
No start up
If your WW3 has batteries it must have spell check or printer options there is a small door on the top right of the machine.
open the door and unplug the plug you find there and try it.
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
Samsung Digimax S500 Digital Camera Logo
42 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
