Question about HP Compaq nc6220 Notebook
SATA mode who I found it
I´m try to boot over the network. the problem is I can´t found the option to desable the SATA Nativ mode in my nc6220 notbook
can anybody help me ???
Boot on sata
I found the user manual here :
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-se/e1886_p4p800_se.pdf
Your problem could be in the bios. Press the delete key repeatedly while booting up to enter the Bios Setup Utility and check these options :
IDE Configuration - as shown in the manual at chapter 4 page 14
Onboard PCI IDE Operate Mode - Enhanced Mode
Enhanced Mode Support On - S-ATA
Configure S-ATA as RAID - no
and also
Boot device priority - as shown in the manual at chapter 4 page 33
set your Sata drive as the 1st boot device
For additional info, refer to the manual in the link above.
Did this solve your problem?
Dec 27, 2012 | ASUS P4P800 SE/865PE/SATA/R/A/GBE/1394...
Disk read error windows 7
Check on the BIOS option and try to boot in SATA Mode instead of the AHCI that comes by default some motherboard are not capable to run windows 7 on AHCI Mode. Hopes this helps you.
Best regards Luis!
Jan 13, 2012 | Intel Computers & Internet
Ibm loptop cannot ditict the hardisk
first of all check is it correctly connected or not?
then go to BIOS and there is a option call sata enabled or desabled
desable it and install
more info
servicemanualboy@gmail.com
Jan 05, 2012 | IBM ThinkPad X21 2662 Notebook
The laptops said the operating systems was not found first and now the laptop wont start up.
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 18, 2010 | Gateway MX6453 Notebook
A default profile could not be created because your Mobile Broadband (WWAN) device was not found for xp
Nov 17, 2010 | Acer Aspire One AOA110-1113 Netbook
I hav an acer aspire 4720z laptop ..... which is
I think there is a problem on the hard drive, you should formatting the hard disk using a third party, I usually use Hiren's BootCD that will be found at this link. you will download the file *. iso than burn to a CD, now try to boot from cd rom with that cd inside. later you will see some options there reply from the CD, choose partition magic. from here you will understand what to do next reply. may be useful.
Nov 16, 2009 | Computers & Internet
How can i desable sata hard drive in laptop for installing win XP
in the BIOS you should change the following option
sata native mode should be disable.
Feb 02, 2009 | HP Pavilion dv2000t Notebook
Install xp in compaq presario c700
The hard disk may be set to Enhanced AHCI SATA mode. Look for Legacy or IDE mode setting in BIOS menu options.
XP SP2 does not recognise Enhanced SATA mode hard disks.
see http://www.mydigitallife.info/2007/10/23/windows-xp-setup-could-not-detect-and-find-any-sata-hard-disk-drive-on-ahci-mode/
You may be able to use NLite to make a CD which has correct SATA drivers.
Nov 23, 2008 | Computers & Internet
Problem with install xp in v3777tu
don't disable sata , try changing the mode native to legacy or vics versa
Nov 06, 2008 | Compaq Presario Notebook
HP Compaq nc6220 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
