Question about Refrigerators
My refrigerator door is unusually hard to open, I
My Sub Zero refrigerator door is unusually hard to open, I realize that there is a vacume seal on these doors but it has recently become extremelly difficult to open.
  • 40 Answers
If you open the door and then close it then open it again is difficult normal this happens espeacilly in big volume refrigerators and freezers.You should wait for sometime to open it again as it needs some time to balance the pressure.Warm air goes inside and cools down so the pressure is decreasing.If there is a pressure balance valve installed at the door check it if it funcitons.
Posted on Jun 30, 2009
  • joepurr Sep 04, 2011
    I think there is a vacuum pump on the refrigerator sucking the air out and creating the seal. Other refrigerators don't have this effect and they should cool down the warm air going inside as fast if it was just air cooling creating the effect.
My sub zero has condensation forming inside the refrigerator
Hi - Did you take the vegetable drawers out to see if there is ice in back? If so, you might have a problem with the refrigerator seal. Defrost the ice and then check the seal of the fridge! If you don't have ice behind the drawers, still check to see if the seal is good. When you close the fridge door, it should be very hard to open if you try to re-open it quickly.
Jun 28, 2014 | Sub-Zero 650 / O Bottom Freezer...
Refigerator door doesn't stay sealed shut
Check the seal condition for any damage, crack and etc. Ensure you check the whole seal. Clean the surface (seal and the contact) from any dirt/oil and etc.
Sep 24, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 690 side by side refrigerator . Vacume the condenser light keep on showing after 10 or 12 hrs. Is it possible if both side holding the temprature then it could be door seal?Could some one help me...
That light comes on when the unit is running more than normal to maintain temperature. Have you vacuumed the condenser coil at the top right of the unit? It could be that simple. There is also a fan up top to move air thru the condenser that may be stalling out and not circulating air. The most expensive cause would be a sealed system issue such as a refrigerant leak. With a replacement cost somewhere around $10,000 you may just be better of locating your local authorized service center.
Oct 17, 2013 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero - 700 TCI 2 :Water is forming on bottom of Frig.
Most refrigerator doors are adjustable. You may find that adjusting the door so that there is a proper seal eliminates the water collection problem
Sep 12, 2012 | Sub-Zero 700TC Bottom Freezer Refrigerator
The freeszer door on my Sub Zero does't have suction anymore
what is the mod num> 650, 700? no a lot help. check the freeze inside the upper part for any ice build up
Apr 02, 2010 | Sub-Zero Bottom Freezer Refrigerator
Cannot reopen Sub-Zero 642 freezer door for 50 seconds
Yes, this is normal.  My 642 does the same thing. It seals to be more efficient while trying to cool back down after it has lost heat while open.
Jun 21, 2009 | Sub-Zero 700TR
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 makes loud gurgling sound
gurgling is not unusual and is caused exactly by fluid bubbling thro a pipe.
Nov 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
New 642 freezer door is very hard to open due to seal sticking
If the seal or seating area is sticky, wash it with warm water. If it isn't, this is just the sign of a good refrigerator. As the air cools, it becomes more dense and creates a vacuum inside the compartment. With a pliable new door seal which is sealing well, combined with a large door, this can cause a great seal with alot of pressure pulling on it. Smile, this is why your consumers bill will be much better with that new sub-z.
Oct 17, 2008 | Sub-Zero 642
Refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
May 16, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Refrigerators Logo
2,611 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
