Question about Boating
Fuel ratio mixture!
Evinrude 2-1975 model
    Champion:
  • 207 Answers
50;1
Posted on Jul 02, 2009
What is the fuel to gas ratio for a 7.5 mercury outboard (1975)
Fuel and Gas is the same thing :>)
You mean fuel to oil ratio? 50:1
The 7.5 hp Mercury outboard requires a 50:1 ratio, one pint of 2 cycle oil, to six gallons of fuel.
mercury 7 5 hp outboard fuel mixture Google Search
Use Evinrude XD50, as it is by far the best and has less fumes.
Evinrude XD 50 2 Cycle Oil 2 stroke
Apr 18, 2018 | Mercury Boating
I have an Evinrude 7.5hp outboard motor.Mod# 8RC1A SN# 0178194. What Year of manufd? How to mix fuel & what octane fuel to use & what oil to use? Help me go fishing, thanks.
91 octane rating ( no e-mix fuels ) and proper outboard oil ( not normal engine oil)
outboard oil has a property that allows the oil residue to stick to the metal bits and helps prevent rust
e-mix fuels absorb moisture and and rusts out steel tanks , destroys rubber components and corrodes aluminium components
the model you have is not listed on any 7.5 hp engine from 1950 to 1958
model number starts at 4434 to 7512 to 7525 in 1958
for a better answer , talk with an evinrude service center who should have a chart listing your motor
units with oil injection are 50: 1 ratio and others are 6 gallons to 1 pint of oil which is around 45:1
I would seek advice from an evinrude service center for the correct fuel to oil ratio for your engine
to mix the fuel , put the oil in first then the flow from the bowser will effectively mix it up to start with
then fit the cap on the tank and shake it up yourself
Apr 20, 2017 | Boating
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Down to the final OB code on my truck...Po174
P0174 FORD - Fuel Injection System Too lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
It's a very common problem for the Ford Windstar. Here a link to a web site with information how to repair:
When is the code detected?- Fuel injection system does not operate properly.
- The amount of mixture ratio compensation is too small. (The mixture ratio is too lean.) Symptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Excessive Fuel ConsumptionP0174 FORD Description The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios.
In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light.
Oct 08, 2012 | Cars & Trucks
Fuel oil ratio mixture.
Hello Larry,
Most Boat Engines Run With A 50:1 Ratio
I Think This Is Fine For You.
From The Serial no I Would Say Evinrude
Regards
Gordon
Aug 10, 2012 | Light Outboard Motor Boat Bass Fishing...
I have a code reader and the code is P0171 P0174 System too lean. what makes the system too lean?
P0171 - Fuel Injection System Too Lean Bank 1
Possible Causes:
- Intake air leaks
- Front Heated oxygen sensor may be faulty
- Injectors may be faulty
- Exhaust gas leaks
- Lack of fuel
- Mass air flow sensor may be faulty
- Incorrect PCV hose connection
P0174 - Fuel Injection System Too Lean Bank 2
Possible Causes:
- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
What Causes These Codes: Fuel injection system does not operate properly. The amount of mixture ratio compensation is too large. (The mixture ratio is too rich.) The Powertrain Control Module (PCM) monitors the engine Air/Fuel mixture ratio, the actual mixture ratio can be brought closely to the theoretical mixture ratio based on the mixture ratio feedback signal from the heated oxygen sensors 1. The PCM calculates the necessary compensation to correct the offset between the actual and the theoretical ratios. In case the amount of the compensation value is extremely large (The actual mixture ratio is too lean.), the PCM judges the condition as the fuel injection system malfunction and light up the engine light. The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jan 16, 2011 | 2000 Ford Explorer
Boating Logo
111 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
