Question about D-Link (DVG-3004S) (DVG3004S)
How to program dvg-3004 and dvg-2004 across a lan network .I want to transfer four analog PSTN LINES across a LAN network
  • 400 Answers
See if this download help because i'm using TP-LINK and D-LINK both are almost same this works for me hope work for you...
http://www.sharewareconnection.com/download-wtm-software-distribution-from-sharecon.html
Posted on Jun 30, 2009
  • 3,230 Answers
Check the following link for complete information -
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx
Good Luck!!
Thanks
I have a D-link DGS-1005G. I have two computers connected and a printer. The D-Link is also connected via LAN. I can obtain internet connection to each computer with wireless and the printer will not...
Hi, you have to set up your printer as a device that can be communicated in your LAN by the two PCs.
To set up your printer properly in the LAN, you need to assign a fixed IP to this printer such that whenever it is switch on again, both PC still communicate to this printer without changing the new IP assigned to this printer.
You need to set up this fixed IP properly in your DLink router. For guidance please check this in your user manual of the Dlink. Please let me know any problem you may have again in future.
Aug 10, 2011 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
How to setup my LAN connection? I can not see any LAN card settings, but it has a LAN card physically?
If you are certain it has a LAN card, you can check the Device Manager, as it should show up under the network devices group. If not there, than most likely the driver for the network card is missing.
You can download that from the PC manufacturer, or use a driver finder program to locate it.
Dec 26, 2010 | Acer TravelMate 202T Notebook
Lan driver problem
A D-Link Router is a "plug-and-use" device.
Just connect its 'WAN' port to your cable-modem (or DSL-modem) and connect one 'LAN' port to the network-port on your computer, and you'll be connected -- there is no need for a "LAN-driver" for the DVG-2001S Router.
Apr 16, 2010 | D-Link (DVG-2001S) Router (DVG2001S)
One static IP has internet. how on a LAN?
You need two network adopters in your system.
Connect Internet connection in first Network card and from the other network card give it to your Switch or hub
If you are using XP system you can use Internet connection sharing to share the internet in your LAN systems.
Follow the steps to enable using ICS
1.Enable Internet Connection sharing in the LAN properties in the first network card.
2.Now your second network card automatically get an IP address in the range of 192.168.*.* series
3.Connect other systems in the LAN and make sure the system has selected Optain IP atomatically from DHCP.
You are all set.
There is also an advanced way to setup this .
Install IPCOP firewall in a system with two network cards and u can share the internet with the firewall settings
Aug 28, 2009 | Computers & Internet
Need to know how to install lan card
yes its plug & play device, actually your system can detect such device like your new LAN card. The device is still on your Device Manager but not totally working, need to install first its software to run that new LAN Card.
If you don't what kind of your new LAN card, just install a program that identify the name & model of your LAN card device. Here is the link to install that freeware software www.astra32.com run this program to diagnose the system and identify of your new LAN card device. Good luck!
Jul 25, 2009 | IBM (02K2776) Pentium II, 350 MHz...
What is the difference between wireless router and a LAN router?
You can a wireless router that does the same thing as a LAN router, but you may have a cable LAN router that doesn't host clients wirelessly.
The basic funtion of both is to correctly route network traffic for the intended recipient. The information can be from computer to computer or across intranets (normally high-end switches are used instead) or from the internet through a modem (modulator demodulator) to computers connected to the router (wirelesslor cable).
The difference being, the cable LAN router is connected by a ethernet cable and is capable of faster nominal transfer speeds and a wireless is able to transfer information across a 2.4GHz radio signal.
Don't knock the speed of the wifi, though. I quite happily stream movies from my server to my TV through a wireless connection.
May 10, 2009 | Edimax BR-6114Wg Router (BR6114WG)
Audiocodes MP118 8 FXO early media to Freeswitch SIP extension
Hi, man.
There are many things to consider in this type of application.
when calling from PSTN to IP using analog lines from time to time you will have this type of event, I suggest working with H323 protocol, this will tone down a bit your problem.
If you want optimum performance, you should use a DID with the channels you need and address to your PBX SIP FreeSwitch. The DIDs are cheaper and are digital which eliminates random connectivity problems in the incoming call.
Once you have directed the DID you tell your server to transfer the call to the IVR using your internal dialing plan.
Lucky
Oct 06, 2008 | AudioCodes MP118 Analog Modem
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Internet
There is no utility that comes natively with XP to monitor traffic on an ICS connected LAN. I assume you are not directly connected to the ICS computer, and are running through a Switch or Hub? And you do not have access to this to see how many lines are connected?
If this is the case, you can download and install a packet sniffer and place it within the LAN in front of the ICS computer. It will 'see' all packets traveling across the wire, and report the MAC addresses and IP Addresses to which they are bound. Since every NIC has a unique MAC address (and IP Address), you can see how many computers (NICs) there are in the LAN, and connected to the wire.
http://en.wikipedia.org/wiki/Packet_sniffer
Ethereal:
http://www.ethereal.com/download.html
You can also use a utility like LanGuard Analyzer to search for all computers on the LAN:
http://www.gfi.com/lannetscan/
The last time I checked the trial version is fully operational for 30 days.. I use it in my Corporate LAN to monitor all 1000 computers in my domain.
One other thing to keep in mind, since ICS uses the Class C subnet (this cannot be changed), it has a limit of 254 clients that can be attached.. just an FYI..
Nov 21, 2007 | Computers & Internet
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
See all D-Link (DVG-3004S) (DVG3004S) Questions
D-Link (DVG-3004S) (DVG3004S) Logo
51 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
