Question about IBM Office Equipment & Supplies
Screwy lettering The IBM Wheelwriter 1500 in my office was working fine until I tried to type an envelope. Now all of the letters are screwed up. ''S'' types an ''E''
  • IBM Master
  • 3,594 Answers
Check to see if you are in the language mode, the lang light on the right will be lit. Code "L" willturn it off.
DickyO
Posted on Jun 30, 2009
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
IBM wheelwriter types wrong letters
Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co.
@ 800-392-8085.
DickyO
Dec 14, 2009 | IBM Wheelwriter 30 Typewriter
Only some of the keys work.
The keyboard is probably bad contact Geo. Beyers Co. 1-800-392-8085.DickyO
Apr 09, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter II problem - the letters aren't getting struck.
There is a pad on the end of the printhammer cylenoid, that contacts the printhammer, and causes it to function. It sounds like this is what happened. The pad is made of a yellowish opaque plastic. Get a flashlight and look down the left side of the printhammer. Down toward the bottom there is a screw with a locknut where the pad contacts the printhammer. There you will see the remains of the pad, the pad, or a bright shinny metal rod that the pad usually sits on. The solutions are, replace the pad, or the whole cylenoid with a pad installed, or adjust the screw until it contacts the cylenoid (which is best done with the printhead removed from the machine.
It also could be a bad cylenoid, bad circuit board, or bad power supply.
Oct 24, 2008 | Lexmark Wheelwriter 15 Series II...
IBM Personal Wheelwriter 2
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
DickyO
Jul 02, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
IBM 1500 by Lexmark
It sounds to me like the impression is to heavy try holding the code key down and pressing the "Q" key until the "1" light is lit.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
43 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
