Computers & Internet Logo
Posted on Jun 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Drive won't mount
The drive won't mount. There was a storm this morning, and since then the drive will spin and the light comes on but the icon won't mount on the desktop.
Anonymous
Level 3:
President:
  • Master 392 Answers
  • Posted on Jun 30, 2009
Anonymous
Master
Level 3:
President:
Answers
392
Questions
Helped
168000
Points
1574
Then the hard disk got spoiled. replacement is the only solution.
Trailblazer idles rough in the morning,and while in drive at a stop light
Maybe a miss fire going on...can also b motor/tranny mount go in bad...in my car I notice if I put it in neutral at a light the vibration goes away when its a mount...
Geo storm alternator light comes on while ideling
belt slippping.
bad alt (reg)
battery has issues. even corroded bat lugs.
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Fujistu MJA2250BH Spinning but won't mount
Hard to say what the problem may be with out more information.
You may ask the guys at http://FreeDataRecovery.us to look at it for you.
Storm knocked power off late yesterday afternoon....back on this morning. PC won't power up....small green light on back flashing. Modem, router, etc. all back up and running, but PC won't turn...
The first thing to try is to cycle the power. To do this, unplug the power cord from the back of the PC and press and hold down the power button on the PC for 5 seconds. This will completely drain any "stuck" power in the components. Now plug the power back into the PC and try booting. If it still does not come back on after this, then you may be dealing with a blown power supply. You can buy replacement power supplies from your local PC shop for about $50 for a 400watt.
To protect your devices in the future, make sure you have a good surge protector and / or a UPS (uninterrupted power supply).
Regards, Chris
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
1helpful
External Firewire drive won't mount any more
This model appears to have a high failure rate in consumer reviews, so it may have physical damage on the disk. Only a re-format of the drive will isolate bad sectors that won't hold data. Try re-mounting your drive after a fresh re-boot of your computer. If the drive came with the manufacture's software to allow it to communicate with your computer, then try removing this software from your system and re-installing it again. This will repair a corrupt driver or I/O program. Try using the drive with a new or different firewire cable. Other users have reported this drive working again after replacing the cable. If you use Mac OS 10.2, you might not be able to initialize or partition the hard drive. This may require you to partition and format the drive on a different computer. From your brief description, it sounds as though you may need to re-format the drive before it will work again.
Grand Canyon Tech
Grand Canyon Tech
