Power button doesn't work
SOURCE: Acer Aspire 4720 PC Notebook doesn,t start in the evening hours
All drivers for Acer Aspire 4720Z model can be downloaded from ftp server of europe.acer.com site or from the link of acer.co.in
Due to resemblence of motherboard of Acer Travel Mate 6292, the drivers for this model & 4720Z are the same.
This information is given to me from Acer Service Centre .
you can sms them with serial no. along the problem. they will revert to u in 1 hr. 100% good service.
you can contact me at [email protected]
Acer SMS centre for cust care: 09901676677
Arun Kanojia
Pune
SOURCE: I have a acer aspire
click on the start button, click on programs, and click on acer clear eye,,,,I am using this same puter right now
SOURCE: acer aspire 7741Z-5731 won't boot
Corrupted windows installation. If you can boot to safe mode, run a disc check and see if that resolves the issue, If it does not, or you cannot access it in safe mode, you need to repair your version of windows with the install disc.
Testimonial: "Very quick and helpful information"
SOURCE: I have an Acer Aspire 7741Z. I need to replace the
go on ebay and put you computers madel number in and put the compters name which is acer than put keybords. if you aready have one than the way you could put it in is to remove the part that your power button is on. Befor you do so uplug the computer and remove th power cord than check for screws on the back there shuld be three or four screws to remove, than than remove the three screws than your keybord should liftup and has a little ribben than has to be unplugged than put the new one in than it shuld work
SOURCE: How do In use the
Hello, to use the built in recovery with your laptop you need to do a few things. First, turn off your computer. When turning it back on immediately start pressing F8 until you get the advanced boot options screen. An option there should be repair my computer. If that does not work, you want to do the same thing but press F4 instead of F8 constantly. If F4 does not work then you want to press F9. Try them in that order and you should be taken care of.
Thanks for using FixYa!
