Question about Cuisinart DGB-500 Coffee Maker
Can you tell me what type of screw driver it takes to remover the bottom of the DGB-500 coffee maker?
2 Suggested Answers
SOURCE:
  • 3 Answers
SOURCE: Can you tell me what type of screw driver it takes
It's a Torx, size T-9. When I got mine at Home Depot a few years ago, they weren't available individually, only in a somewhat-pricey set of 5 sizes.
Posted on Oct 11, 2010
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Can you tell me what type of screw driver it takes to remover the bottom of the DGB-600 coffee maker?
Sep 22, 2010 | Cuisinart DGB-600 Coffee Maker
DGB 500 Grinder
You may try opening the front cover first and removing the filter then after opening the top lid, remove the clear grinder cover and lift the grinder from the rear. After you get it out be sure to clean the motor drive shaft and the bottom of the grinder. then use a trace of vegetable oil to lubricate the motor shaft where is attaches to the grinder.
We are on our second coffee maker and it makes great coffee.
Jan 19, 2009 | Cuisinart DGB-500 Coffee Maker
Won't start
DGB-300 - continuously beeping indicates that something is out of place - either the grind basket isn't exactly in place, the filter basket is loose, the water filter holder is out of place, or the lid of the coffee maker is open.
-Tha Mp3 Doctor
Jun 23, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisnart DGB-500 shuts off before coffee brewing is complete.
I had the same problem. I ran it about 5 times with vinegar / water solution. A lot of hard water deposits (solids) showed up in the filter! The coffee maker now runs all the way to completion!
As a note, I live in an area with extremely hard water.
Apr 11, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Aug 30, 2007 | Cuisinart DGB-300 Coffee Maker
Cuisinart DGB-500 Coffee Maker Logo
46 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
