Question about Black & Decker Garden
Gls 220 auto strimmer
Not sure how to load the spool every time I thread the line it will not auto feed and breaks the line
  • ronaldh Jul 07, 2009
    thanks for your answer but thats not the problem as I purchased a pre loaded spoil ,my problem is were to fed the plastic line through as there is a slot or a small hole on top of the plastic spoil holder Ron H
  • 1,041 Answers
When putting new line on, it must be wound clockwise onto the spool
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
The top thread keeps breaking
Is the thread feeding freely from the spool? Sometimes thread can get caught on something on the thread spool which causes it to snap at the needle. I suggest unthreading, and running your finger around the rim of the spool to be sure there is nothing for the thread to catch on. Then be sure to use your spool pin disks to ensure the thread is feeding well.
Mar 03, 2015 | PfaFF Creative 7570
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Rethreading a garden strimmer
Hi Deborah,
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Black & Decker Garden
My prdect is fashionaire 2380.when i'm sew somthing it's break the thread,and it's stack
Check the thread spool to see if there is a nick where the thread is catching. If there is, you can smooth away the nick with an emery board, or just flip the spool so the thread is feeding from the bottom of the spool.
Sometimes the thread feeds too quickly from the spool and puddles around the spool pin. A thread net (can be purchased online or at a sewing machine dealer) can eliminate this.
Check the threading to be sure it is correct - always thread to top thread with the presser foot up.
Check the bobbin to be sure the thread is feeding from the bobbin spool in the correct direction and through the correct guides.
Refer to your manual for threading and bobbin position.
Feb 20, 2010 | White Sewing Fashionaire Sewing 2380...
Strimmer cord keeps breaking
the eyelets on the trimmer head may be worn and cutting the line ..look for groves in the eyeleys may need to replace the spool
Sep 01, 2009 | Garden
Spool removal impossible
The thing is with strimmers, mower etc.
Depending on which direction the designers have made it spin, they normally have a 'reverse' threaded, head.
Simply 'Tighten' it up to remove, and 'undo' it, to tighten.
Et voila!
Happy strimming:))
Jul 28, 2009 | Garden
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 | Garden
Spool not auto feeding on gl701 and need diagram of how to set it up correctly in strimmer
When putting new line on, it must be wound clockwise onto spool. Make sure to use the correct size line.
Jim
Jul 01, 2009 | Black & Decker Garden
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Garden Logo
407 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
