Question about Dometic Rooftop RV Air Conditioner
AC main Breaker
My problem is a little different. I have lived in Las Vegas for 3 yrs and about 2 weeks ago the AC breaker triped at about 7PM and wood keep triping all night and in the morning. At about 9am it will run till about 7 ot 9 pm when the temp starts going down and then starts triping. I went and got a new breaker but it still trips.
  • 43 Answers
There are many things that would cause this problem. It would be best to have a qualified technician test your system to find the cause.
Posted on Jun 30, 2009
Breaker keep triping on screen light shows P-06
Is it tripping under load? or not under load. If it is under load have breaker checked and unit tested on a load bank. If it trips under no load check for wiring shorts on the main AC lines to the plugs
Oct 02, 2013 | Kipor Electrical Supplies
What is the best limo company in Las Vegas?
Checkout Uber. They are On-Demand Limo service across US. You gotta download their mobile app though.
Very reasonable price and little wait time.
Feb 05, 2013 | Cell Phones
About 2 months ago my Main Breaker in my 100 amp service box began tripping when certain large appliances were running the same time my central air unit was running. Nothing has changed as far as...
Well breakers can weaken overtime if they are overloaded. A breaker is meant to have 80% of its capacity used, for example a 20 amp breaker should have only 16 amps of current on it. If something was changed six years ago that has loaded that breaker to its max it may have not affected it until now. Another thing would to be absolutely sure that everything running in your house is not exceeding 100 amps. Many houses these days have 200 amp panels because of how much amperage added appliance and the like will use. A licensed electrician will be needed to swap out the breaker, which will be a little expensive but shouldn't be outrageous as he will not be swapping out the whole panel, just the main breaker.
May 23, 2010 | Square D Qo 100 Amp Breaker Box Qo120m100...
Dishwasher tripped our main circuit breaker.
It may be that your water pump is leaking on to the motor...
Dec 09, 2009 | KitchenAid KUDR01TJ Dishwasher
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
BenQ 8700 Won't Power On
As far as the projector goes, the ac power supply is fused with probably no more than a 7 amp fuse, that would blow before your breaker would if the problem were in the projector. The only thing that could case the breaker to trip would be a defective AC outlet socket or your cord for the projector is bad. I have seen cases where cat's have chewed though the cord and shorted it out and triped a breaker, outside of that if the projector is bad now then your thought of sending to the manufacturer is the best one.
Jun 07, 2009 | Televison & Video
Dometic Rooftop RV Air Conditioner Logo
121 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
