Question about Young Living Essential Oil Diffuser - Green
Why is my diffuser is not working as it should - no steam coming out
There is no steam coming out, the jet of water is very weak and not reaching the cap.
Steam won't come out Shark steam mop
I found mine to to becaused by hard water deposits. Our tape water has all kinds of minerals in it. & after time the jets get plugged solid with white calcium scale. hard as a rock. Best solution is to disassemble & hone each jet hole. It dose take some time, but that will work. & for now on use distilled water or at least filtered is better than nothing. Hope this helps?
Apr 03, 2017 | Shark Vacuums
No steam - steam jet does not heat
just clean the valve...
u wi get fixed sir..
Apr 21, 2008 | Pasquini Livietta T2 Espresso Machine
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
I need the impeller and diffuser for an water jet pump Utilitech UTP20P1
Home Depot Lowes This is where the only place I have ever seen these brand of pump. Try there.
Feb 20, 2015 | Pool & Spa
Water will not come through the brewing head. I have tried priming it by passing water through the steam pipe as described in the manual and although water comes through the steam pipe it still will not...
Either the screen is blocked or the valve seat is clogged. Remove the screw and screen make sure you can see light through every hole in the screen. Now try to run the head if water flows, screen was dirty if no water, remove 2 allen wrench screws and diffuser and spring and valve(DO NOT LOSE SPRING AND VALVE), run the head, if water flows the blockage is clear re assemble and you are back in business. Here is a little pic to help you on the way.
Jan 16, 2011 | Gaggia Classic Espresso Machine
Jets weak
Remove your filter cartridge and test again. If flow is still low, then check for debris plugging the inlet to the pump. If removing the cartridge resolves the flow issue, then clean the filter or replace it.
Apr 02, 2010 | Qca Spas Morocco Spa
ECM Giotto releases steam instead of water from the coffee group
Check the shower screen and diffuser in the head, they might be blocked, if not, check the metering jet at the top of the head(large nut) CAREFUL, make sure machine is off and cool before removing, use a paperclip or pipe cleaner to clear blockage. If not blocked then you will have to check the brew solenoid.
Mar 02, 2010 | ECM Giotto Espresso Machine
Gaggia baby espresso machine - water comes out of steam wand but not group head. tried priming, cleaning
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
Oct 21, 2009 | Gaggia Baby Espresso Machine
My Gaggia Baby C coffee maker has stopped pumping water
From what you have asked the only thing I can suggest is that the pump needs to be replaced. Do you hear the pump vibrating? The lines from the pump may be blocked. Have you tried to descale the machine.
Jun 06, 2009 | Gaggia Baby Espresso Machine
Young Living Essential Oil Diffuser - Green Logo
436 people viewed this question
Top Young Living Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Young Living Health and Beauty Expert? Answer questions, earn points and help others
