Question about Canon LaserClass 9000L Plain Paper Fax
Error message saying "supply rec. paper"
The paper tray button is flashing, but I have paper in the fax.
  • 318 Answers
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Posted on Jul 03, 2009
I am getting flashing error messages 'Supply REC. Paper Tray: LTR' and 'Received in Memory'. There is no paper jam and there is paper loaded in the tray. I have also tried to manually feed paper. I have...
Hi there:
I had the same problem and it made me crazy. All you have to do is pull out the paper tray, pinch the very back wall of it (I think it has a blue button to pinch) and slide the very back of it forward so the paper is snug in the tray. Put the tray back in and it should go away. :)
Hope I helped........
Mar 09, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Error message - "check Rec. Paper"
Check rec. paper means that the paper may not be routed properly thro' the cutter mechanism and out thro' the machine....if it is; then the sensors that detect the paper may be dirty or faulty.
Mar 31, 2008 | Muratec M1250 Fax
Canon LaserClass 9000L Plain Paper Fax Logo
650 people viewed this question
old marine
old marine
