SOURCE: Brother MFC-240C Control Center
Follow the instructions on this page and reinstall your driver for Vista.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlf/000000/002700/dlf002700.html?reg=us&c=us&lang=en&prod=mfc240c_all&type2=1&os=74&flang=8&dlid=dlf002700
Hope it helps!
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
SOURCE: Over-ride out of ink message Brother MFC-240C
Yes, you can cut a small piece of electrical tape and place it over the window on the inside edge of the cartridge. it has to wrap around the window tightly.
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: brother mfc-440cn cannot get control center 3 to run with it
Verify that it is still installed.
Click the start button on the task bar to view the programs, then look for The Brother submenu and follow it to the icon representing the control Center 3 and press enter. It will activate and an icon will show on the task bar.
Hope it helps.
