Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
SAME SAME GREEN PICTURE AFTER CHANGE THE BULB
  • 616 Answers
What you need is an optical block, contact sony and ask about the optical block program, they will have someone come to your home and install it for free.tvs from 2006 to present. Julio
Posted on Aug 01, 2009
  • 261 Answers
This sounds more likely to be an issue with you digital video board, for more accurate troueblshoot, discountdashmerchantdotcom
Posted on Jul 23, 2009
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
When powered on, the green standby light continues to blink until it eventually turns red and the cool down process begins. The set top box is powered on but the picture never comes on.
The most common cause of No Picture - Lights Flashing, or Intermittent Picture - Picture Cuts Out in all Sony LCD TVs is bulb failure.
No troubleshooting or replacing parts should be attempted without installing a "known" good bulb. This is not a fault, the mercury in the bulb has been consumed.
Many dollars are spent on parts and service when the only problem is bulb failure.
You can replace the complete Lamp Assembly or the Bare Bulb. DIY or get a serviceman. Here is a link that shows how to change or replace the bulb or lamp in Sony KF50WE610.
Sony Lamp, Bulb, Installation Guide
Dec 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
No picture - green light flicking on and off
Bulb light indicator flashes?Projection bulb use alot,an awile like about 1 or 2.The projection bulb must change it at end of it life cycles.
Apr 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Green does come up on the flash focus and think
bulb actually called the green picture tube (crt) is fine. the problem is that you have a picture mute problem. suggest local service center
Nov 11, 2009 | Sony KP-61S70 61" Rear Projection...
CHANGE BULB SOUND WORKBUT NO PICTURE.GREEN LIGHT
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Televison & Video
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/red-crt/cName/phillipsmagnavox-tv-parts
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
