Question about Cameras
Autofocus doesn't work at all. - Cameras
  • Obertelli
    Obertelli May 11, 2010
    Which make and model are you asking about? At the moment this question is impossible to answer without reading your mind ;-)
  • 685 Answers
Depending upon which brand and model it may be worth sending that lens in for repair.
Posted on Nov 24, 2009
Autofocus on Nikkor 18-55mm lens doesn't work
probably you have problem with the focus motor, i ever have same problem and need to replaced the focus motor.
Jun 08, 2013 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I have a AF Nikkor 70-210 which I use with a DSRL camera. But I want to buy a analogic one. Should I buy an AF one, or the lens will still full working (including the autofocus) with a manual one, like a...
The lens will work with any Nikon film SLR, including the FG-20. However, the FG-20 is not an autofocus camera. Whether the lens is capable of autofocusing or not, you'll still have to focus manually. With a newer autofocus camera, such as the N75 and N80, the lens will autofocus.
Mar 13, 2012 | Cameras
The auto focus does not work properly with this lens on either my Nikon D5000 or D7000. I have tried all possible combinations of AF settings. Typicaly, when I use single point to focus, the subject I...
Hi, It wouldn't autofocus on the D5000 as the body doesn't have an auto focus motor in the body and since that lens is AF, not AF-S, it won't autofocus. It should autofocus on the D7000 though, how far away are you from the object you're trying to photograph?
Aug 28, 2011 | Tamron SP AF 17-50mm f/2.8 XR Di II LD...
What digital nikon cam works autofocus in a nikkor micro AF 105mm f/2.8D?
This lens lacks the autofocus motor, so it will only autofocus on cameras with the motor. This lens will autofocus on every Nikon digital SLR except for the D40, D40x, D60, D3000, D3100, D5000, and D5100. It will autofocus with the D1 family, D2 family, D3 family, D50, D70, D70s, D80, D90, D100, D200, D300, D300s, and D700 (I hope I haven't left any out).
Jul 03, 2011 | Nikon Cameras
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
Autofocus
Reset.
Press and Hold the INFO button near the trigger and 'I' button at left side bottom for few seconds. Once the information appears on the LCD screen, your autofocus should be working.
Orelse, carry it to an authorised service centre.
May 14, 2010 | Nikon D5000 Digital Camera
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Autoocus doesn't work
The first thing to check is that autofocus is enabled on the camera body.
The auto/manual focus selector switch is located on the front of the camera, just below the lens release button (on the left side as you look through the view finder). Make sure that the white dot on the selector lines up with the white dot under the AF (autofocus).
If this does not solve the problem, make sure that your lenses are set to autofocus mode as well.
Dec 25, 2008 | Nikon CA-1104-SMK for D70SLR
Nikon D50 autofocus
Same happened to mine ,Its almost as though the motor has dis-engaged.I SOLVED MINE BY FORCING THE FOCUS RING WITH AUTOFOCUS ENGAGED THIS SEEMS TO HAVE RE ENGAGED THE MOTOR .HOWEVER BE CAREFUL I HAD LITTLE TO LOSE MINE WAS STILL UNDER WARRANTY WHEN I DID THIS.Its perfect since.
Jan 12, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Cameras Logo
326 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
