Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
How to get to the door cable and pulley that
How do I get to the door cable and pulley that squeaks when the door is open and shut?
You need to pull out the dishwasher from under the counter and it runs along the bottom on each side.
Posted on Jul 28, 2009
When i turn on my car i hear squeaking sound
Belts? Mice? Hallucination? ALL DEPENDS ON WHERE THE "SQUEAKING" IS COMING FROM.
Open the hood. If the squeaking is coming from the area of the serpentine belt, it is probably time to replace your belt. Also, check all fluid levels.
If the squeaking is coming from a particular pulley (such as the air conditioning compressor or the power steering hydraulic pump), there may be a problem with whatever the pulley is attached to.
If the squeaking appears to be coming from outside of the car, you are scaring the mice or hallucinating.
Jul 17, 2014 | 2006 Honda Accord
Tip
Door sqeaking or falling down? - KitchenAid Kenmore Whirlpool
If the door on your have a stainless steel tank dishwasher is making an annoying squeaking sound or simply drops open unless you support it there is a solution.
The system used to open the door and hold it in place on these models uses rope cables and pulleys. As dust and dirt get on the cables they would make noise usually a creaking or squeaking noise. Sometimes the cables would break causing the door to fall.
The fix for this is a new set of cables and pulleys. They are of a different material that will resist the attraction of dust build up and stay quiet. The link on the end of the ropes have been reinforced to help prevent breaking and the pulleys are of a different bearing design. Over all a very good replacement part.
The part number for this kit is 8194001.(See image below) It comes complete with parts for both sides, be sure to replace both sides even if the noise is only coming from one side. It comes with 2 ropes (24), 2 pulleys (9 &17).
Disconnect the power or unplug the power cord before working on this!
To replace you will need to pull the dishwasher out from the cabinet opening about a foot. Look at the plumbing and electrical to make sure there is enough length to move it out.
Once out you will see the cable (24) that attaches to the spring (18) and to the hinge on the door (not shown), replace the cable and pulley (9).
Do one side at a time, if one side is broken do that side first so you have a a guide to look at if you forget where something goes.
I like to snap a digital picture before I start so I can reference back if I forget what goes where.
on May 02, 2010 | Dishwashers
My garage door won't close ... starts to close but at different points it stops and opens again
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4.
Dec 31, 2010 | liftmaster Chamberlain Garage Door Opener...
GARAGE DOOR WANT CLOSE, USING CLOSER WILL MOVE A LITTLE BUT LIGHT FLASHES, SENSORS SEEM TO BE WORKING
I recommend this to everyone with garage door opener problems:
If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well.
Dec 07, 2010 | liftmaster Chamberlain Garage Door Opener...
The passenger side power sliding door on my 2003 Silhouette binds up when opening and shuts automatically before fully opens. I have disabled the power control to the door to open manuallly. It still is...
sounds as if the cable is shot which means that the motor will have to be replaced cause i think after 01 they went from cable pulley to sleeved cable and cause of the frayed cable in the sleeve is causing the stiff door btw i have installed power sliding doors on my 02 venture and know the system intimatly
Sep 11, 2010 | 2001 Oldsmobile Silhouette
Makes a squeaking noise when it spins
it's either a roller or the belt pulley,there's a belt kit you can buy that has a belt rollers and pulley,it's cheaper to buy it like that and has everything you'll need,next time send the model number,it will start with 110. or 417. and eight numbers after the dot,it's located around the door opening where you put the clothes into the dryer,NOT ON THE DOOR
Aug 29, 2010 | Kenmore 73952 Gas Dryer
My Liftmaster Formula 1 garage door opener has started to shut unevenly, making one side of the closed door slightly higher than the other. This leaves a gap under the closed door on one side. The door...
my friend had the same problem and yes that is what we did. It took a wile to set it evenly. Wouldn't think it would take long but it did. We inadvertently set them to tight and door wouldn't close it would reverse on itself because of the added tension. In the end we did get it though.
Feb 04, 2010 | liftmaster Chamberlain Garage Door Opener...
Door drops when opened
your door's hinge link is broken
Pull your dishwasher from under counter (you may need to disconnect hoses and power connnections, so turn off power at the circuit breaker). Look for the broken rope-like item and replace it. Use the other side as an example on how to re-install the link. Attach link to spring, hook spring back into frame/chassis, threaded link through pulleys, attach other end of link onto door then reinstall dishwasher under counter. My replacement link package came as a pair, so replace both at the same time. The other side may still be attached and functioning, but will most likely show signs of wear.
Dec 13, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Model #MDG8506AWW Dryer with a SQUEAK
a) most likely cause of squeak is from rear rollers, and idler pulley itself. replace all three if your gonna open.
b) front panel comes off by first removing the door 2 screws and then the opposing side also has similar 2 screws after removing them the front panel falls forward and comes off, then 3 5/16 screws on either sides remove the front bulkhead. giving access to the inner workings
Mar 15, 2008 | Dryers
Squeaky door
On our KitchenAid dishwasher we had the same problem--a REALLY loud squeak as it opened. The sound comes from the nylon rope slipping along the plastic pulleys. We've had the DW for about 3 years and the noise has gotten worse over time. I was determined to win the war against the noise and am happy to say I fixed it today.
The trick is to use a dry lubricant on the cord and on the pulleys. I used Dry Graphite by Gunk. It comes in an aerosol spray can and once the stuff dried the squeak was gone. I'll let you know if it comes back...
May 16, 2007 | KitchenAid 24 in. KUDS01FLBL Built-in...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
274 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
