Motherboard will not acivate power to monitor,usb ports. cpu fan starts up normally thengoes into high speed???
    Problem Solver:
  • 10 Answers
Actually your Motherboard is knackered - i had this when i built my own shuttle sn26p 4 years ago.
Motherboard was sent back and they replaced it,
the fans were on turbo as soon as you switched on - the bios maybe also flashed again if you can get into it as nothing loads as you say.... just send it back to the manufacturer - it's more common than you think with the shuttle
Posted on Oct 11, 2009
Testimonial: "The solution was right on! Thank you!~"
    Genius:
  • 1,066 Answers
Your power supply prolly isnt giving it enuf power
Posted on Jul 01, 2009
Why is power up for intel DQ965CO start up unreliable?
"No bios screen" If you mean that the screen is totally dead with no response at all, but when you power-up you DO hear the normal system beep, then first check your video cable to make sure connections are tight. Take the monitor and plug it into a different computer to make sure that the monitor has failed or not. If the monitor tests good, your case cooling fans and the CPU heatsink fan do spin up, if you do not get the usual system beep when booting, then you have a low-level failure of a component. This could be caused by only one of three things: your CPU (processor) has failed, the motherboard has failed, or possibly there is a problem with the power supply. I hang out at www.suggest-a-fix.com which is a free computer help forum. Post in the Hardware section and I will be along. This forum is not set up for complicated problems that require back-and-forth, in-depth communication.
Jul 27, 2014 | Intel Desktop Board DQ965CO - motherboard...
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Can I put a dual core processor on my Chaintech S1689 mother board--Athlon 64 FX w/ 939 socket? I don't think my CPU fan is working and I need to replace it.
Form Factor: ATX (305mm x 200mm)
CPU: Supports Socket-939 Athlon 64 / Athlon 64 FX and Dual-Core (X2) / Sempron with the new v6.0 BIOS and above. Processor interface via 2000MT/s HyperTransport bus.
Chipset: ULi M1689
Main Memory: Four 184-pin DDR DIMM up to 4GB Supports Dual Channel DDR266/333/400 memory.
Expansion Slots: X4/X8 AGP Slot and Five 32bit PCI Slots (v2.2 compliant)
Audio: Realtek ALC850 with 8 Channels
SATA: Supports 2 Serial ATA devices for the highest data transfer rates (1.5Gbps burst) with RAID 0 & RAID 1 solution.
UltraDMA IDE Ports: Supports 2 UltraDMA-66/100/133 IDE ports
FDD: One FDD connector supports up to 2.88MB
USB 2.0: Supports total 8 USB2.0 ports with High-Speed Devices at 480 Mb/s Transfer Rates
System monitoring: Two Temperature and Fan Sensors for CPU and System
Jun 01, 2009 | AMD Athlon 64 Socket 939 Chaintech S1689...
CPU Fan Speed Too Low or Fails***
There are three things you need to have a good gaming computer, fast graphics card, fast CPU, and lots of RAM. You didn't list your RAM so I can't help you, but 4GB is the most you can put in a computer. If you want to know everything about your computer then click on Start>Accesssories>system tools>system.
Ok you asked four or five questions so lets start with the CPU since if that breaks nothing else matters. First, the measurement for CPU is GigaHertz (GHz) not rpm. So it looks like you have a 1.98GHz CPU. That is not extremely fast (my Dell laptop for instance has a 2.4GHz) so you don't have to worry about your CPU overheating. Yes, all CPUs should have a heatsink and a fan. It helps with the cooling. A CPU also does a thing called "throttling" if it is getting too hot it slows itself down to cool off. So you are good with the CPU.
The other fan is the large fan you hear going on and off. That is connected to your power supply. The measurement for that is in wattage, it is custom made depending on the motherboard so that is a given that there is no problems with the power supply.
Both fans on the CPU and the Power Supply will turn off and on as they get hotter then stop when they are cool again.
Your graphics card is the most important for gaming. It should come with its on RAM and it's on fan. GE FORCE makes some good ones. Just google "gaming graphic cards" and you'll get an idea of what you need.
So that's it. Hope this helps you understand more. If you have any questions let me know. Don't forget to rate this solution with four stars before logging out.
Feb 12, 2009 | ViewSonic VX910 19" LCD Monitor
PRINCECHARMING2010@YAHOO.COM
CPU
  1. LGA 775 for Intel® Pentium® D / Pentium® 4 processor
Chipset
  1. North Bridge : Intel® 865G GMCH
  2. South Bridge : Intel® ICH5
  3. Realtek ALC653 Codec
  4. EP82562G chip (10/100Mbit)
Front Side Bus
  1. 800 / 533 MHz FSB
Memory
  1. Type: Dual Channel DDR 400 / 333 / 266 support
  2. Max capacity: 2 GB
  3. DIMM slots: 2
* Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. Internal I/O Connectors
  1. 1 20-pin ATX power connector
  2. 1 4-pin ATX 12V power connector
  3. 1 floppy connector
  4. 2 IDE connectors
  5. 2 SATA connectors
  6. 1 CPU fan connector
  7. 1 system fan connector
  8. 1 front panel connector
  9. 1 front audio connector
  10. 1 CD In connector
  11. 1 power LED connector
  12. 1 USB 2.0/1.1 connectors for additional 2 ports by cables
Expansion Slots
  1. 1 x AGP 8x slot
  2. 3 x PCI slots
Back Panel Connectors
  1. 1 PS/2 keyboard port
  2. 1 PS/2 mouse port
  3. 1 parallel port
  4. 1 serial port (COMA)
  5. 1 VGA port
  6. 4 USB 2.0/1.1 ports
  7. 1 RJ-45 port
  8. 3 audio jacks (Line In / Line Out / MIC In)
Form Factor
  1. Micro ATX
  2. 24.4cm x 21.2cm
H/W Monitoring
  1. System voltage detection
  2. CPU temperature detection
  3. CPU / System fan speed detection
  4. CPU warning temperature
  5. CPU / System fan failure warning
  6. CPU smart fan control
BIOS
  1. 3Mbit flash ROM
  2. Use of licensed AWARD BIOS
Other Features
  1. Supports @BIOS
  2. Supports Download Center
  3. Supports Q-Flash
  4. Supports EasyTune 5 (only supports Hardware Monitor function)
  5. Supports Xpress Install
  6. Supports Xpress Recovery2
  7. Supports Xpress BIOS rescue
Remark
  1. Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
  2. Due to most hardware/software vendors no longer offer support for Win9X/ME. If some vendors still has Win9X/ME drivers available, we will publish on website
Jan 16, 2009 | Computers & Internet
Mother not working
You blew out the motherboard, cpu & ram may have survived, but I would guess that high of a voltage would have fried the mobo
Jun 20, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
CPU fan races
turn up the task manager to monitor the cpu load. use ctrl shift esc to bring it up. now open up an application. see as the cpu meter goes from low to full green (high).. then check if the fan also speeds up. i guess you have a cmos setup on the motherboard that monitors cpu load and speeds up the fan.
as for the usb -speaker, please explain further..
May 20, 2008 | Car Audio & Video
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Computers & Internet Logo
291 people viewed this question
David Payne
David Payne
