Question about Apex Digital PF3230 32" TV
Apex PF3230 TV with pincushion problem.
The sides of the picture on my tv started curving inward displaying an hourglass effect. From what I read, it is a pincushion problem. I don't have and can't find a service manual for this set, so I don't know where the pincushion area of the mainboard is. Any help would be appreciated.
  • 47 Answers
Too dangerous for a home repair as this requires replacement high voltage components and adjusting the set with the back off while running.
Take to repair store.
Posted on Feb 26, 2008
Picture is squished in from the sides. Sides are curved inward like a fat hourglass. Vertical setting seems okay. Is there a horizontal adjustment somewhere? or is the issue more complex
Unfortunately from your description this a complex issue and cannot be adjusted out. The cause is a shorted winding in the horizontal section of the yoke, or the high voltage capacitor has decreased in value causing the hourglass effect, depending on the problem will dicktate cost to repair, I suggest an estimate before a decision is made, and if the set is more than five to ten years old consideration should be given in a replacement.
Aug 20, 2011 | Philips 30PW8402 30" TV
The picture on the tv is curved in the middle sides if the screen how do i fix it to where the picture fills the whole screen?
Their are pincushion circuits the compensate for inward curvature. It is common for solder connections to break on the pincushion transformers or the connections where the transformer wire is wrapped around the connector pin. Careful inspection under a magnifying glass while manipulating the pin sometime will show hairline cracks in the solder. Their are also adjustments on the convergence board that will compensate. The adjustment potentiometers on the convergence board also have shown to be prone to solder cracking on the PC board
Oct 13, 2009 | Televison & Video
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Jan 08, 2009 | RCA F32632SB 32" TV
Zenith Projection TV PVY5265RK hourglass
i would start there, or send the board in and have it checked out at
Convergence amp ic bad
Feb 06, 2008 | Televison & Video
Help for part number
Flyback Transformer L1479 030530-5282 Apex Tv. Model #PF3230
Nov 17, 2007 | Apex Digital PF3230 32" TV
IBM G74 Monitor
CRT monitors suffer from the so-called pincushion effect. It is the curving of the actual video picture usually inwards on the sides. There is often an adjustment to compensate for this and it's usually situated near the other user controls. Look for it in you manual.
Now, because of magnetism differences in the world. The monitor is setup to work where it was built. The pincushion effect get worse over time. The degree of severity depends on the location of the monitor and the quality of the design of it to facilitate enough future re-adjustment by turning the pincushion knob.
Nov 03, 2007 | IBM G74 17 in.CRT Conventional Monitor
Loewe TV with pin cushion distortion
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Oct 05, 2007 | Televison & Video
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Hourglass shape on left and right side-ballpark repair price please
The shape your seeing is called 'V Bow' and 'Pincushion' which needs to be calibrated again. Theres probably a diode that went out. The tech can open it up and adjust the angles back. I wouldn't charge over $100-$150. Shop around for a good repair tech. Good Luck poe_diddley.
Jul 13, 2007 | Samsung TXN3071WHF 30" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Apex Digital PF3230 32" TV Logo
242 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
