Question about Toyo 45CX Film Camera
How do you change out the bellows of a Toyo 45D view camera
Toyo 500mm lens to nikon d90 mount
At the risk of being obvious, you need a Nikon mount.
The lens comes with a T-mount. This is a "universal" mount with adapters for almost any camera mount, including the Nikon F mount. If the lens doesn't come with one, get a Nikon T-mount adapter.
The lens doesn't have any electronics, so you'll be shooting completely manual. No autofocus, no autoexposure, not even any exposure help from the camera's light meter.
Feb 23, 2013 | Konica Minolta Minolta Telephoto Camera...
Hi < I have have just aquired a5x4 toyo view C camera. the upright sections with the racks are worn, can I get spares for these or even a complete standard. Regards Jim
You can order parts for most Toyo cameras direct from Toyo. You'd have to contact them directly for pricing, and they'd either give you something there, or refer you to one of their dealers to handle it. They have a website, toyoview.com from which you can get contact information.
Sep 06, 2011 | Toyo -View 4x5 45CF Field Camera with...
2005 navi sys. wont read disc. Toyota want 3-4K to fix. Now after a $700.00 tune up, the back up camera,display, and steering wheel controls for radio/dvd system do not work. I only have 57k miles. Now...
I would raise all holy hell with Toyo. You only have 57000 miles on your veh. and all of this is not working...Demand that whomever did the tune up reconnect the camera and display.
Now the navi system is all together a 'separate' system. I realize they use the same screen but internally they are two different components....I don't work for crutchfield, but they sell factory units for your vehicle that look superb, and are muuuuuuch cheaper that what toyo quoted you, 3-4k is outrageous! crutchfield.com has them for maybe $400-600 and they are an upgrage from the factory unit as well...they are completely compatable with your rear camera, navi, stereo...hope this helps
Jan 28, 2010 | 2006 Toyota Sienna
I have a 2008 highlander hybrid limited
Contact the Toyo company. toyota will not help you on this one. You need to check to see if there is unusual shredding or peeling or possibly chunks coming off the tires. That is what happened with mine at 14K miles and I am in the process of getting them replaced. Toyota service told me they thought it was normal wear. It was not. After I contacted Toyo, they told me to go to a toyo dealer and have them call the company back. They offered me 100% if I put the same A20 tire onthe vehicle and 70% (100% for unused spare) if I put the new Toyo HT. I chose the latter since it has a 60K mile warranty. What I also found out is the A20 tire is not the same one you can buy now. The new one is the A20A. The original A20 was made specifically for Toyota at their request as an OEM tire. Toyota should have some liability in this and I am fighting them for the 30% cost, but am not holding my breath they will help.
Then only manufacturer of the 245/55R19 is Bridgestone and Toyo at this time.
Jul 10, 2009 | 2008 Toyota Highlander
Toyo 19" A20 Tires wearing out quickly
Jul 07, 2009 | 2008 Toyota Highlander
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
I don't know how to use my lens
go to " graflex- kodak shutter and lenses" for your manual and break down.
May 30, 2009 | Toyo -View 4x5 45CF Field Camera with...
Right side Toyo 45E post guides
Chances are slim that you will find anyone with the parts. As a camera repairman, I would have never stocked those parts, trusting the distributor, in this case MAC group, to provide them when and if I ever needed them. I don't have a parts diagram for that camera to look at, so can't advise about the cost to "fabricate" the post guides, but short of finding a dead 45E to salvage from,it might be your only hope
Dec 24, 2008 | Toyo -View 4x5 45CF Field Camera with...
Toyo 45CX Film Camera Logo
155 people viewed this question
Top Toyo Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Toyo Photography Expert? Answer questions, earn points and help others
