Question about XO Vision XOD1735 Car DVD Player
Problem w/ touch sceen
It flickers from color to black and white.and the back to color. could there be some type of shortage?
Yes it can be faulty ribbon cable, slack connection on the cable that attach to the touch screen.
I had that problem too, actually it was slack connection on touch screen
Posted on Jul 02, 2009
  • 1 more comment
  • cam1164 Jul 05, 2011
    how to fix this problem
    where can i have it repaired
    small ribbon wire off inside head unit help
My color went out and how can i get my color back on my sceen and so color show
When you view any photo on your computer or print out a picture, is it also not in color? If that is the case, I would suspect it is a setting somewhere in the camera menu and it is set to black and white. Cameras allow you to change colors to b&w, sepia, polarize etc. and this may be what you are seeing.
Sep 02, 2015 | Cameras
Black and wight picture
The tv have a colors wheel.The tv make humming,buzzing motor loud noises or flickering black and white pictures.The colors wheel is dead,require changing,bcause of the colors wheel axsis rubbing on it sides or worn out,than have black & white pictures.Hire a tv tech, to do the job.Because changing the colors wheel is not easy.Require take out many machanicals parts,before even can change the colors wheel it self.
Sep 01, 2010 | Samsung DLP HL-P5663W 56" TV
Anyone know why my color input is coming out in black and white? the on sceen menu and dvd's are in color
Have you tried reprograming your dvd, you must also save the changes that you made during reprograming.
Aug 21, 2010 | Pioneer DVR-520H DVD Recorder
Iv Changed My Phone Case From Black To white iv by mistake broke the ribbion that holds the LCD sceen. i cant get my touch screen to work HELP !!
simply chane your touch screen . hope it helps. because anything that is damage which is used on the processing of the response on the touch screen. it would impede the normal response of your phone.
Aug 06, 2010 | Nokia 5530 XpressMusic Smartphone
Lg env touch internal screen flickers white/colors after h20 expo
go ahead and take it apart... but be extra careful with the flex part,, dont use aclohol it may corrode some parts, try using lacquer flo, and dry it out with mild heat using hair blower or some sorts
maybe that would fix it, but if the lines you are saying doesnt go off, well you have no choice but to replace the lcd itself
Nov 10, 2009 | LG enV VX9900 Cellular Phone
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
Lcd touch sceen needs resetting it is misalinged
you get to the touch sceen by holdin down the frist tow buttons and turning the machine on the singer sceen will turn on just touch the sceen and you will see a small black box touch the box and it should move touch it four times and then touch the stright stiche white button at the bottum of the sceen it will save the settings and it will work .
Jan 14, 2009 | Singer Quantum XL-1000 Computerized Sewing...
Color flickers on and off
I went to the Sony support page for your model.(link below)http://esupport.sony.com/US/perl/model-home.pl?mdl=KP61V85&LOC=3
They are undergoing maintenance right now, so I couldn't find any answers for you. I would check back with the website to see if they can help you. If the Standby timer light flashes, you may need to have the TV repaired. There is a "Hot Topics" section for "How to troubleshoot television picture issues" that will probably be very helpful to you.
Dec 05, 2008 | Televison & Video
Touch Screen bad on a XL1000
I have posted the answer to this problem if the sceen is misaligned just turn off the machine and hold down the frist to buttons turn the machine back on the singer sceen shows up touch ithe sceen it should freeze and then a small black box should show up touch the box and it should move to a differant spot touch it four times and then rub you finger accross the stright stiche white button at the bottum of the sceen this saves the changes.
Nov 08, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Wiring in Ceiling fan remote. Lights flicker
dip switches are not on the same signal?
Sep 07, 2008 | Hunter 27185 Remote Control
XO Vision XOD1735 Car DVD Player Logo
255 people viewed this question
Top XO Vision Car Audio & Video Experts
jason
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
