Kenmore elite washer metal band on gray seal
The metal band that holds the gray rubber seal between the door opening and the basket has come off - how do i put it back on?
  • 5,911 Answers
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Posted on Jun 30, 2009
How to remove remove rubber seal between door and drum
Hi,the door seal is held in place with a wire with spring on it,just open door get hold of rubber witch is attatched where door closes,
if you pull on the rubber at the edge you will see the wire you will have to get a flathead screwdriver to prise it out,once you take the metal band off just pull the rubber off,then if you pull on the rubber the inside bit of the rubber will come out.
hope this was some help.
Apr 05, 2015 | Zanussi Washing Machines
How do you get rubber boot and plastic ring off the machine just inside the door
hi, kev if you open the door and look at the hole where latch connects you should see 2 screws undo them this will release the metal band that sits on the outside of the door. once this is off just pull the rubber away from the front, the next bit is a bit tricky. you may have to take the top off the washer for the next part. you will have to reach down and unscrew the large metal band that holds the rubber seal on to the drum good luck hope it helps. if you still get stuck try this website www.espares.co.uk there may be a video on how to change it
regards
shaun
Nov 05, 2011 | GE WBVH6240F Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
Water leaking out of door , seems like it might be a problem with the door hinge ?
Not likely that you have a hinge problem, but it can happen, especially if water has been dribbling down the back side of the front panel from the dispenser area, getting on the hinge, and causing it to bind up. Replacing the hinge is a pain because the screws are put in with thread lock, requiring heating or even drilling in some cases. If you have water dripping down the front of the machine from the door, the most common reason is that there is some lint or hair on the bottom side of the glass door, preventing a complete seal to the gray rubber gasket. Generally, just cleaning off the bottom of the glass door will fix it. If that does not do it, you can try moving the spring clamp (which holds the front of the gray tub seal) from the bottom (6 O'clock position) to the hinge area (9 O'clock position) Sometimes, the leak is caused because someone pushed the washer into place by placing their hands just below the door and actually deformed the metal front panel inward, preventing a seal between the door glass and the gray tub seal. If that is the case, it may be corrected by removing the spring retaining clamp, taking the front of the gray tub seal off, pulling outward a bit on the metal panel at the bottom of the door openings, and replacing the seal and retaining band again.
May 09, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to replace the rubber gasket around door and drum
open the door around the front of the door seal you will see a lip under the lip you will see a metal band will a spring. get a screw driver and push in on the spring and pop it out. this will remove the front of the seal next is the same thing exept the band looks a little different locate the part that you can unscrew sometimes they have a socket head and sometimes it will have a phillips screw. when you are putting it back on it may be time consuming and you may start to cuss a little. you have to make sure the rubber goes on the right way so that the band seals and doesn';t fall off or you will have a leaking issue. also when taking the seal off you have to take the part that the water comes in off. just peal the rubber away from that plastic shoot. let me know if you have any more questions
Apr 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Front Load Washer
The rubber boot is called the "door bellow". The following link explains how to replace one:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If the bellow is not ripped or torn, you probably will NOT have to replace it. If the front bellow clamp (wire hoop) is the only thing that came loose, you will need to reseat the bellow around the door frame opening and reinsert the bellow clamp. The link explains this in Step 12 (I suggest you use a second set of hands to assist you). Now...if the bellow is torn, or if the clamp is damaged, you will need replacment parts. Let me know if you require additional assistance. I hope this helps you.
Oct 10, 2008 | Washing Machines
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
