Question about NorStar T7316E Corded Phone
Simply want to turn ringer off at my phone for external incoming calls
Hi. I would like to turn off the ringer at my phone for external incoming calls, but still be able to be notified within my office when the call is for me.
  • 201 Answers
Re: simply want to turn ringer off at my phone for...
How do you want to be notified? How do you determine if a call is for you? Does an operator answer the call and transfer it to your extension? If so, you just need to change programming for your phone so it does not ring for incoming calls. It would still ring if a call is transfered to you. Programming is changed in the phone system, not the telephone. Your phone can be used on different Nortel systems that program differently so you need to find out which system you have and locate the manual for that or pay a local installation company to make the changes.
Posted on Nov 12, 2007
0 characters
3 Points
How do I turn the ringer on at my phone for external incoming calls?
how did you turn it off . there are so many different makes and models and few are the same .
Nov 23, 2015 | Phones
How do I turn the ringer off at my phone for external incoming calls?
Go into the extension programming and change the line settings to no ring. It is best done if you have a display phone so you can see the changes. If not, then you will need to look at the flashing line lights when you enter the programming mode.
Press Feature 00. This will take you into the programming mode. You should see the line buttons lit up green. They will be Solid (Immediate Ring) or Slow Flash (Delayed Ring) or Fast Flash (No Ring). I assume yours is solid so push each line button until it changes to a fast flash. Once done press Feature 00 to exit the system and save the settings.
Sep 11, 2014 | Avaya Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
Adjusting the Earpiece.
**Here is also a link to the phone manual
May 18, 2011 | Uniden Cordless Phone
M7208n phone - mute ringer for external calls
Incoming line ring settings are in the config menu under:
2nd option - Line access
enter extension number
2nd option - Ringing
Ringing then can be toggled on or off for each line assigned to that extension.
Jul 15, 2009 | Nortel Meridian M7208 Corded Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
Volume off on incoming calls
There are two ways 1) as your looking at your phone on the top left side of the unit there is an little toggle switch to turn the ringer of or down just a bit. 2) (navagator key) in the bottom right hand corner there is a circle with four arrows on it simply press the down arrow until it says ringer off
Jan 07, 2009 | Panasonic KX-T7730 Corded Phone
No ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
Mar 30, 2008 | Panasonic KX-TG6052B Phone
Unable to dial out, check voice mail and see call display
Hi at the back of the phone you will see a selectable Hi/Lo/Off switch. Slide the (Ringer) switch to High position or Low position to turn the ringer on. Hi for high volume Lo for low volume.
To prevent hearing any ringing of incoming calls slide the (ringer) switch to the off position but when you ready to accept incoming calls again remember to slide the switch back to either Hi or Low setting. Hope this made sense and helped.
Oct 24, 2007 | Curtis Trimline TID582 Corded Phone
RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
NorStar T7316E Corded Phone Logo
1,424 people viewed this question
Top NorStar Phones Experts
Are you a NorStar Phone Expert? Answer questions, earn points and help others
