Watter dripping inside my apartment (the a/c unit has already been profesionally tilted outside) Thank you!
  • 43 Answers
It sounds like you may have a condensation drain problem. Shut the unit off to stop the water problem and call a qualified technician to clear the condensation drain and test for other problems.
Posted on Jun 30, 2009
My window unit air conditioner unit is dripping profusely out of the bottom of the unit inside of my apartment. the drip pan is overflowing.
Hello, make sure the unit is tilted toward the outside a bit, if it is level the condensate will collect in the front and start dripping inside the house. Also, if the unit has a drain make sure it is clean so the water can drain out properly.
Jun 04, 2011 | Frigidaire Heating & Cooling
I have a sharp cv-10 MH and it is leaking at the bottom towards the front any ideas on how i could fix this or what it could be?
Window units do produce water in operation but it normally drips to the outside on the ground. If your unit is tilted too much toward the front making it un level the water can drip to the inside. Change the tilt to the outside.
Apr 22, 2011 | Sharp AF-S120FX Air Conditioner
HEAVY WIND NOISE FREQUENTLY COMES, SIMILAR TO A STORM. FROM MY 1.5 TON **** LG UNIT
It is ttime tto et your AC serviced.Remove the front filter after removing the front grille , then take the full ocver after removing the screws from within.
Now pull the whole set out and take it outside. Use a good watter jet to clean the dirt in the condenser coils , the fan and the inside.
Finally use a good air jet to clean up all the clogged fins.
Have the filters cleaned. now check by manual rotation of the fan if there is bearing noise. use some light oil to lubricate the ends so lessen the sound, plug it outside and test. if sound has redduced wsh offf with oil once again, if not the bush/bearing must be changed.
reset the whole unit back to test.
Sep 18, 2010 | LG LS-K1830CL Cool Mini Split Air...
My ac is spitting watter by the vent, and making noise i think it happends when the fan inside hits the water that acumulates inside is there something i can do to fix this and make the water go out
The AC fan is blowing the water that has condensed on the cooling pipes.It is possible that there is clogging of dirt in the fins of the cooling pipe'
this results in water logging.The filters must be clogged and dirt has accumalated.Use a good air spray or a water jet to clean.The condensed water must flow to the rear of the unit to drain out .{A/C must be fitted slightly tilted.}.Hope this helps.
Aug 29, 2010 | Goldstar LG L1004R Window Air Conditioner
Water leaking onto the sump unsure if heater hose split
?antifreeze or watter ? inside car or out? if it is leaking inside chance are it is a heater core ..if out side passengers side it could be ac condensation could be inside too if drain is plugged and if it is water if it is watter and not antifreeze the drain is behind Eng lower firewall short black hose with flat end you can clean it with a pipe cleaner sort is the car loosing antifreeze
Mar 11, 2010 | 1995 Mazda MPV
What are some compatible power supply upgrades?
Well you can go up to a 1000 Watter! but i suspect that may be "Overkill" what you most likely need is a 550 watter or maybe a 650 Watt Unit. The existing 500 Watter is NO slouch though, and I wonder if that may not just do the job anyway?
Mar 07, 2010 | E-Machines eMachines Desktop PC
I was using the iron and then there was no heat even thought it was still plugged in--the light on the iron went out while still plugged in
there are 2 possibilities what could be wrong
First one is that you didn't use distilled watter (you could use regular) by doing so a small coat of watter stone is covering all internal parts
Mix some vinegar with watter (ration 5 watter 1 vineger) and putt it in iron and than it will start breaking watter stone, you should use some cloaf that u don't need to wipe off exces watter stone, don't get burned!
DO NOT IRON WHILE DONG THIS
Second one is that there is a cable problem, but this is a big problem...
Oct 18, 2009 | Rowenta Irons
Amana AP095R Portable Air Conditioner is dripping water constantly. It didn't use to do this. What's wrong here?
all air conditioners condense water .. the water is normally drained to the outside thru a hole near the outside bottom of the unit .. the unit has to be mounted so that it doesnt tilt inward .. the drain hole has to be cleaned once in a while ... if its clogged or if the unit is tilted inward then the water will drain inside the house .. less likely but possible is a cracked or damaged drip pan inside the unit ... thats a shallow pan under the condenser (cold) coil that captures the water and directs it toward the outside drain .. so check the tilt and clean the drain
Aug 17, 2009 | Heating & Cooling
Heating & Cooling Logo
228 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
