Question about Dell UltraSharp 2007WFP Monitor
Will not turn on. i have tried different outlets different cords and different computer.. it will not turn on
    Brigadier General:
  • 10,406 Answers
There are no "user-serviceable" parts inside a LCD monitor.
So, all you can do is to take it to a qualified TV/video technician, for trouble-shooting. Or, just responsibly recycle it, and buy a new one. Some stores may give you a "trade-in" on the old one, because the LCD screen itself may be OK, i.e., the problem is in the "electronics".
Posted on Jun 10, 2010
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
Brother MFC 250C has no power and will not turn on. The power cord is plugged in and turned on but yet there's power to it?
For general troubleshoot of any no power device is always just:
Try a different power cord (these cords are all the same, you can use a standard computer cord)
Try a different power outlet (no surge protector, direct to wall to a known working outlet)
If it still gets no power at all the the power supply has probably gone bad and will need to be replaced.
If the machine is out of warranty however the cost to repair it will probably be more than the cost of replacing the unit with a new one.
Your best bet would be to call around your local printer repair shops and see if they have any of these models on hand as spare part donor machines.
Jun 10, 2011 | Brother MFC 240C All-In-One InkJet Printer
I turned my e-machine T5010 few days ago and it immediately shut down and did not power again after that...how can i fix?
After you moved or turned your computer desktop it stopped turning on? When you moved it, you may have dislodged the power connections. Double check the power cord and make sure it is snuggly fit into the back of the computer and the other end into the wall outlet. If possible, try a new wall outlet.
If you are still having trouble, make sure your power supply it turned on(usually a power switch on the back of it). You can also try a different power cord if you have one available.
Regards,
G33k
May 10, 2011 | Computers & Internet
Monitor shuts off
Is the monitor light turning off, indicating the monitor is turning off? Or is the monitor/computer going to sleep?
How do you get the monitor to turn back on?
Verify the power cord is securely plugged into both the monitor and the outlet.
Try a different outlet.
Mar 12, 2011 | ViewSonic VX715 17" LCD Monitor
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
Printer not turning on
Try wiggle the power cord Then try different power cord
Apr 23, 2009 | HP DeskJet F380 All-In-One Printer
No electric power to the computer, it won't turn on
Some things to try (some may sound obvious - you might want to try them anyway)
  1. A new power cord.
  2. A different power strip (if using one)
  3. A different outlet.
If not, it probably means either the switch to power it on is broken, or your power supply is dead. Both are cheap to fix.
Mar 20, 2009 | Compaq Presario S6500NX (DQ181A#ABA) PC...
PS3 starts but wont turn on
you could have a problem with your power cord which is causing your ps3 to short before the system can power on fully. try using a different power cord or check the ports of both the outlet and the ps3 to make sure there is nothing blocking anything. also, try using a different outlet.
Oct 14, 2008 | Sony Playstation 3 (PS3) Console
My PC won't power on.
First, check all connections insid the computer. then,depending on your skill level and warranty status, you can try the following:
Remove or disconnect all accessories from the pc (Hard drive, floppy, cd/dvd roms and accessory cards) Then see if it will turn on. If yes, the replace the items one by one unrtil it fails.
If no, then you must either try a different (known good) power supply on your motherboard. (you can also see if your power supply powers a known good motherboard).
If not, the you motherboard is likey faulty.
Jun 02, 2008 | E-Machines T3985 PC Desktop
Compaq intel pentium 42.8ghz512mb
How old is your computer? Did you recently have a power outage or anything? Most the time if a computer won't turn on, something in it went bad OR an outlet is bad. Try this:
1. Make sure that the power switch is on, the switch in the back (on the power supply itself) is turned on, and everything along those lines is functioning.
2. If that doesn't work, and it will not power on AT ALL, make sure the cords are plugged firmly in place, including the surge protector and/or the power cord itself.
3. Try resetting the surge suppressor and/or plug the computer into a different outlet in the surge suppressor. Try other items in that surge suppressor (or even in the wall outlet, if that's what you're plugged into) to make sure that the outlet itself is working.
4. If your computer is plugged directly into a working wall or surge suppressor outlet, try a different power cord.
5. If your surge suppressor works, your wall outlet has power to it, and you are using a known-good power cord in the computer, you will have to go into more in-depth investigation as something inside the computer likely went bad. It could be the video card, motherboard, CPU fan, power button, or the power supply itself. Start by testing the video card and the power supply by (one at a time) swapping out a known-good component for the one you suspect may be bad. If it won't turn on after that, try swapping out the next and try it again. If it still will not work, it could be something more serious such as the motherboard or power button.
it could be a bad power supply or a bad motherboard. Other problems might cause issues, such as a bad video card.
Jan 16, 2008 | Computers & Internet
Dell UltraSharp 2007WFP Monitor Logo
283 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
