Question about Vivitar ViviCam 5100 Digital Camera
Blurry pictures My camera has two settings on the front. One is to take still pictures, such as flowers, the other setting is for action shots. My camera will not switch back to the action setting. There is a switch on the front of the camera. I have switched it to the right position, and it won't work. I have also taken the batteries out of the camera and switched it again. No dice. This sucks because I am missing a lot of good pictures of my kids. please help.
  • 797 Answers
Re: Blurry pictures
Try this... Go to the setup menu and RESET ALL. Then test.
If this does not make a diff.then the camera may need repair.
Here is a support you could call or email:
Go to:
Ask for your model.
Posted on Sep 29, 2008
0 characters
3 Points
My new Nikon S8100 keeps taking blurry photos. It claims to have subject tracking to help capture the perfect shot, but my shots of my daughter's laughter on her swing set are all blurry, as well are my...
Tracking a subject is one thing but, taking an action picture is something else altogether. You will need to set the ISO to a higher number to force the shutter to set a faster speed stop the action.
Feb 24, 2011 | Nikon S8100 Digital Camera
I like to get up close pics of objects especially plants and scenery. The problem is when I zoom in the picture is always blurry and cannot focus on objects that are not far away. Is there anyway setting...
most cameras come with an option called macro,this setting is for close up shots.on your camera it needs to set at wide angle.when choosing the shooting mode move left or right and choose the icon of a flower.if you adjust the zoom, a zoom bar will appear at the top of the lcd.if you try to use a zoom not intended for macro shots the flower icon will gray out and the bar will appear yellow,if you take a picture with the yellow bar it will be blurry.if you zoom out a little until it stops you should be ok. if you use a flash in macro mode the images edges usually will darken.hope this helps.
Jan 08, 2011 | Canon PowerShot SX100 IS Digital Camera
Canon Powershot SX10is All my action shots in
you should set it to a high shutter speed and f/stop also set your pictures to a RAW setting, if that made no sences let me know, and i'll say it abit more simple :)
Apr 22, 2010 | Canon PowerShot SX10 IS Digital Camera
Blurry action pictures
The sport setting uses a faster shutter speed to stop motion. However, if you have the ISO set to a low number and try to take action shots in dim light, they will be blurry. Either use auto ISO or use a higher number such as 400 or 800.
Sep 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have the Nikon D60 - Ive taken sport/action pictures
The main difference between the two shooting conditions is the amount of light you have to work with. For the indoor action shots, set the ISO setting to the highest available through the menu (1600 ISO) to maximize the ability of the camera to work with the diminished light. The other (but more expensive) way to achieve better indoor shots is with the use of a "faster" lens, ie one with a lower maximum f stop number (f2.8 is faster than f3.5, for instance). Also ensure you are shooting with your lens at its widest f stop setting (lowest number).
Jul 26, 2009 | Nikon D60 Digital Camera
Out of focus shot on Auto setting
Do you have it inn "macro" mode? See the little flower/mountain button on the back of your camera. Press it once until the mountain icon shows on the screen. This is for normal "distant" photos. Or press it once more until the little flower icon reappears. This is for extreme close-ups, like taking pictures of flowers. This sounds like what you probably had it in.
But really, your little camera can do so much more. Recommend that you take a look at this. It's an 8 mb download, but you should read it:
Jun 04, 2009 | Canon PowerShot SD1000 Digital Camera
Is there a adjustment button somewhere on the camera for taking pictures at close range? When I take a close up shot it is blurry. Let me know if any kind of adjustment can be made. get back to me at...
It's hidden, right there on the front of the unit! On the distant setting (mountain icon) it will focus down to 60cm; on the close-up setting, called "macro" by photographers, (flower icon) it will focus down to 10cm.
Feb 27, 2009 | HP Photosmart E317 Digital Camera
It's probably stuck on the macro setting (flower icon on the front of the unit) so it will only focus close to things. Try sliding it to the mountain icon for regular pictures.
Oct 02, 2008 | HP Photosmart E317 Digital Camera
Focus problems
Just turn off macro mode - that's it...
Feb 06, 2008 | Digital Cameras
Vivitar ViviCam 5100 Digital Camera Logo
27 people viewed this question
Top Vivitar Digital Cameras Experts
Are you a Vivitar Digital Camera Expert? Answer questions, earn points and help others
