Question about Peavey Pv 2600 Power Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
HELP PROVIDE PEAVEY XR684 TRANSISTOR ARRANGEMENT
    Novelist:
  • 157 Answers
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Posted on Aug 21, 2009
    Champion:
  • 243 Answers
Peavey XR684 Power OutPut Devices Are As Follows:
2SC5200/2SA1943 Complementary Pairs From Toshiba.
Posted on Nov 06, 2013
    New Friend:
There was some component on the board like felt or transistors and i have missed them so help me to fix them is inside the peavey tnt 115 600watts bass combo.
Posted on Nov 12, 2012
Wish to bridge onto mixer output to send to separate amp for use in another part of bldg. without interfearing with regular speakers. Peavey XR684
simple !! most peavey mixers have a monitor output !! you can use that to feed new amp , and theres your volume too !!! or if your already using the monitor output , you can buy a split cable (1 in 2 outs) for main send !! this cable would have to be kept short or it will induce HUMMM !! and in real extreme cases if your using a low Z send (cant think as to why ) a device known as a (direct box) normally used by instrument sends can be used in reverse to "tap" into a low Z send and output with a unbalanced send for an amp to your other room , but hey why not just add a speaker with a volume control to it for this smaller room ? and forgo the new amp
Oct 05, 2016 | Peavey Music
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Setting up pv20 usb
http://www.peavey.com/products/index.cfm/item/699/116338/PV%26nbsp%3B20%26nbsp%3BUSB
Look under "Downloads" tab at bottom for owners manual info. In a nutshell...mic to mixer channel #1, mixer connected to power amplifier, amplifier connected to speakers. Start with zero volumes on all equipment, bring up amps 1st (1/2 volume) and then adjust mixer until sound is heard from the microphone.
Oct 31, 2012 | Peavey Music
How do i connect my behringer ha400 headphone amp to my peavey xr684
You can hook'em up utilizing the front low-level main outputs of your peavey684 to your headphone amp inputs, this should do the job satisfactorily.
Oct 18, 2012 | Peavey Electronics Peavey 00512140 PV 14...
I have 110v XR 1220 power mixer and friend of mine plug into 240v power point, blown the two transistors ou. I do not know what short of transistors are they?
There are dozens of transistors in the unit... we can't guess which you might be refering to. The power supply of the 1200 series mixers have fuse before each part of the supply for the preamp sections.
Jul 13, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
Trying to find the mute j111 on xr684f
I don't believe there is a mute function on the XR684F unit. There is a mute on the XR8600 but they probably use different boards in it. The mute button for the XR8300 and XR8600 are near the effects selector button and LIKELY is board mounted and would not have a J111 connector. If the electrical function is in the XR684, it MAY just be pads like test points, to only be used during testing and troubleshooting.
Mar 21, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
While using my xr684 for practice at home,there was a loud noise and a smell of burning electic circuit,so I turned off.a friend who used to work in the amplifier business looked at it for me and said it...
Probably one of the two amplifiers in it had a failure. It is probably economically repairable by a COMPETENT technician. I would expect several transistors have failed probably $30 if parts maximum.
I would NOT suggest using it with the failure as further damage or even a slight fire hazard might exist.
Bad or intermittent speaker cables are common cause of this type failure. Overdriving or even a bad speaker can also cause it.
Oct 07, 2009 | Peavey Music
PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
Jan 07, 2009 | Peavey Music
Peavey Pv 2600 Power Amplifier Logo
669 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Peavey Music Expert? Answer questions, earn points and help others
