SOURCE: Need Unlock code.. pls help!
Try online at www.mobile2mobile.net , www.unlockitnow.com or try taking it to a mobile service center and have them unlock the phone for a fee.
SOURCE: what is the code to unlock this phone? Pantech
you can unlock your phone here http://www.superunlockcodes.com/pantech-p7000/rs12wp9/
They will provide the code when you enter your imei number,you just need to select your phone model and network provider
SOURCE: how do I change the
Changing mobile phone housing are usually quite straight forward. First take off the back of the phone where the battery goes in next try to determine if the back casing of the phone is screwed to the front. If yes locate the screws and take them out to allow for ease of removal of both the front and the back. Although often times the casing is usually still held in place by clipings which are in built with the casing.
Also you must know that the screws which are used for mobile phones are mostly different from the conventional star of flat screw drivers. So incase your screw driver does not open it do not force it as the screw combination might be different.
Hope this solution has been helpful?
