Question about U-Line 15R Compact Refrigerator
Chefmate compact refrigerator
Just stopped working only 7months old wont keep things cold
  • 286 Answers
Is anything running? IF your fan and compressor are running then you need a service tech to look at the sealed system. If nothing is running then it may be a bad thermostat.
Posted on Aug 16, 2009
My 1.7 cu ft Chefmate refrigerator stopped cooling. It's less than a year old and sits in an office (clean and climate controlled). I tried unplugging it and restarting it with no success. Any ideas?
try to check if compressor working adjust the thermostat to coldness setting if not working possible parts damage check your over load protector or the current relay it is located on the compressor terminal replace if damage.
Mar 07, 2011 | Refrigerators
My chefmate refrigerator is 1yrs old and started making a loud humming noise. What is it and what do I do 2 fix it? Everything inside is still very cold.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Chefmate cooler has a very noisy fan.
Good day,
If the noise is a current problem, and did not exist from new, then the motor bearings are bad, and the motor needs replaced regardless of age.
Note: LG chose not to allow appliance parts houses to carry their parts. Sad, however, you may be able to remove it and go to an appliance parts house and get a decent match. In fact, it may be a better motor.
Failing that, contact your selling dealer to purchase the new motor.
Dec 04, 2009 | LG GC-051SS Compact Refrigerator
I have a Chefmate Mini Fridge - BC-50A that does not work. It appears the heat sink fan and the cold sink fan do not have power to the motor. What do I do? nicole.barnes@parknicollet.com
it could be the thermostat is not switching them on, try changing the settings on them, if it still dont work you may need new thermostats fitted,
Nov 19, 2009 | LG GC-051SS Compact Refrigerator
Chefmate mini fridge no more
OK If this is a U-line refrigerator. Is the compressor running? The Fan? If both are running then you will have a sealed system issue. If nothing is running then it goes to the thermostat. Bypass the 2 wires from the thermostat to see if it runs.Yes, then replace the thermostat.
Jul 21, 2009 | U-Line 15R Compact Refrigerator
Refrigerator does not work. Does not get cold.
Make sure the outlet is working. Maybe try an extension cord. Is it shut off inside? Does the light come on?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 01, 2009 | Globe Chefmate Series Heavy Duty Compact...
(1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Jan 12, 2009 | U-Line 15R Compact Refrigerator
Chefmate RS-06DR mini Fridge (1.6 Cubic Feet)
My chefmate is **** because the internal fan is garbage, its cheap, it doesn't work or give enough flow, try a higher flow unit. You can get the 12v at tigerdirect.com with some high flow (AND LIGHTS :) ) for a few bucks to save your 100 dollar investment. The removal of the orig fan is easy. The evap is a good setup, but the cooling setup for it seems to be sh*t. Cheap fans = cheap setup and this is why everyone hates these units cause it can't pump the goods.
For the record my fan died, so my evap and fan froze over completely and spoiled my food and burned out the fan completely and probably helped to short it. I can get it going if I flicker the fan with my finger but she is dead and can't catch naturally. You could replace the chefmate fan with most computer fans too... fyi if you got a junk tower laying around.
While your at it clean the fans on the back and take off the back panel which kicks out the hot air from the hot flow. It helps if your unit is older (a year plus+ in a dorm is like 4 in a clean house lol)
Nov 03, 2008 | LG GC-051SS Compact Refrigerator
U-Line 15R Compact Refrigerator Logo
869 people viewed this question
Top U-Line Refrigerators Experts
billconfused
Marvin
Marvin
Ilia Bichin
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
