Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 50 "Magnavox rear projection has a vary faint picture
The channel guides & controls diplay normal, but the picture is distorted & faint.
  • 767 Answers
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
sorry
Posted on Jun 30, 2009
Philips Magnavox 9P5031C 50-Inch Projection TV has a red/orange blur the whole picture is blurry
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 04, 2011 | Philips Magnavox 55P9271 55" Rear...
WD-52525 52 in. Rear Projection HDTV Television: my mitsubishi projection tv has a distorted pictur...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Regular picture size shrinks and color fades
This is a common problem on certain models of Philips Magnavox TV sets. The most common symptom is the screen will shrink and expand over and over. After the TV heats up for a while the video will work like normal. After a few weeks or months your TV will eventually stop working and not have video. You can get complete parts and instructions from www.TvRepairKits.com
Jan 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi Model # VS-50609
try to resolder the convergence amp ICs that may help if not the ICs may need to be replaced. Let me know if you need further assistance.
Jun 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Picture problem on 50H82
the hyper module needs replacement or repair.
there are many dried surface mount caps on the board and they are dried out. best let a tech do the job
Jun 17, 2008 | Toshiba 50H82 50" Rear Projection...
Diagonal distorted picture
convergance amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Toshiba 50H72 50" Rear Projection...
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
Projection TV with Distorted picture
You have one of two different problem. You have bad solder connections on the convergence amp IC's, or you have bad convergence amp IC's. By the way it is acting, I bet if you or someone else resolders all of the pins on both IC,s your problem will go away. But if you keep letting it do this, it will most likely cost you double to repair in the future. Good Luck
Aug 11, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
