Question about Brother IntelliFAX 2800 Laser Fax
The lcd is displaying 'low toner' after changing the toner
  • 51 Answers
Remove the toner cart. ang gently shake it from side-to-side (like panning for gold). re-install. If still bad return to store and try another. This is assuming that the machine was workng when toner ran out.
Posted on Jul 07, 2009
Does anyone know how to reset the toner levels in an HL3040, i have put new colour toners in and each is still showing empty
Hey, I've just figured this out myself. Here is the procedure:
1. Open the front cover that gives you access to the toners. 2. Press and hold "Secure Print" and "Cancel" at the same time. You will see "K-TNR-STD" display on the screen. 3. Using the "+" and "-" buttons select the toner you want to reset. 4. Press the "Ok" button. 5. It will display "Ok?" and hit the "Ok" button again to reset the toner. 6. Close the lid.
All done!
Regards, Michael Pasqualone TotalServe Solutions
Nov 01, 2010 | Brother HL3040CN Laser Printer
Change the toner cartridge
There is instruction how to change toner on lcd display of copier, wich pops out when the toner is out.
Jul 21, 2010 | Canon imageRUNNER 2200
How do you reset the toner low LCD message when you change toner cartridge?
I believe you mean, DRUM Reset.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Jan 12, 2010 | Brother MFC-7820N Printer
New cartridge saying low toner
Try these steps:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Let me know if it doesn't work as there is another possible solution.
Sep 01, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printer Says Toner Low, even when I just changed the toner
If this was an OEM cartridge, you may have received a defective one.  I'd suggest contact Brother for a solution.
Nov 26, 2008 | Brother MFC-9420CN All-In-One Laser...
Printer
You will need to manually reset the toner cartridge.
If the Toner Low or Toner Empty message does not automatically clear after a new cartridge is installed, do the following to clear the message manually:
  7. If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Jul 14, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Black Cartridge just changed, but still says K-toner low
The only way to clear the message is to wait until the the display shows XXXX Toner Out, then change the cartridge and the message will clear itself.
May 18, 2008 | Epson AcuLaser C4000 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Brother IntelliFAX 2800 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
