Question about Whirlpool Washing Machines
Washer is starting in mid cycle and not filling with water
  • 370 Answers
Check to see if the cold water selenoid works on washer. You can do this by turning the switch to cold/cold. It sounds the cold water side has gone out which will cause the washer to stop because it rinses on cold
Posted on Jun 30, 2009
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
My washing machine stopped working in mid-cycle. No agitation is going on and I could not drain it but putting to spin.
Make sure the washer fills with cold water from the beginning of the cycle because most washers have a cold only rinse cycle and if your cold water valve is bad then the machine will stop mid cycle because it cannot fill the washer for the rinse cycle. Secondly, it helps to know which washer you have so please enter more info next time you ask a question. Good luck.
Jun 28, 2015 | Whirlpool Washing Machines
Skipping wash cycle
follow this steps and fix it. God bless you
Lid Switch Assembly
Enter your model number to see parts for your washing machine.
Help me find my model number
Water Inlet Valve
Main Control Board
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 13, 2013 | Admiral 3.4 cu. ft. Top Load Washer in...
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | LG Washing Machines
The water starts to come through then just stops and then alarms go off
Oct 05, 2012 | LG WFT1071TP Top Load Washer
Washer stops during rinse cycle and beeps at me
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Whirlpool 1000 w100 stops after filling with water
Sep 30, 2012 | Creda W100FW Front Load Washer
Agitator starts wont quit
see the diagram
Sep 30, 2012 | Frigidaire Washing Machines
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
