BOSCH: How to replace rubber seal (boot) of front loading washer
I have a rip on bottom of the rubber seal (boot) in the opeing of the washing machine (not on door). Unfortunately, this 1/2 in rip leaks quite a bit of water. I've ordered the part but wondering how to replace the boot. I understand there are internal clamps with springs. Thanx in advance!
  • 157 Answers
Remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Posted on Jun 30, 2009
  • Washing Mach... Master
  • 744 Answers
This video will show you how to change a door seal on this Bosch front loader washing machine
Posted on Jul 22, 2013
Leaks left side underneath..only on rinse cycle
You can download the user manual at: http://lesepc.com/uploads/b/bosch-classixx-wfl-2066-manual.pdf
Apr 03, 2015 | Bosch Classixx WFL 2066 Front Load Washer
Water leaking from Bosch washer
Hi check the grey rubber seal around the door to the washer if there's a rip or tear if there is that would be the problem if not check pipes going to pump also water feed etc make sure all on and tight
Dec 23, 2013 | Bosch Axxis WAS24460UC 3.4 Cu. Ft. Front...
Bosch Axxis washer leaks underneath
take top off at back and check valve ,it should be at the top . Also check front rubber boot for rips, this is a big problem in all brands.
Nov 21, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Mold on gray rubber seal in Bosch washing machine
I use to sell bosch front loading washers for about 3 years, its a common problem on all front loading washers. Try a hot wash through the machine, if no joy then remove the seal and wash in hot soapy water. Make sure you replace the seal while its still hot from wasing if you take it off.
If still no joy, the call a service person and replace the seal. Its just one of those things.
Jun 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
The door seal is torn at the bottom and leaks water on the floor
take the top off look down where the seal meets on the drum there should be a metal band the goes all the way round the rubber seal .you should see a long screw and bolt holding the band together unscrew the bolt and pull the seal off . the same on the front of the washer good luck
shaun
Mar 27, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
BOSCH WFMC3200UC WASHER
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Bosch front load needs new gasket
Bosch WFMC 3200 Front Load Washer needs to replace
door gasket.
This video will show you how to change a door seal or gasket on this Bosch front loader washing machine and also where to buy parts!
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2008 | Bosch WFMC 3200 Front Load Washer
Metal ring aroound rubber seal fell off.
Start with the spring at the bottom, work the retainer around until the seal starts to pull away from the washer. Now grip the loop that the spring attaches to on the side that isn't in place and open the retainer. Push the retainer in place and release the spring.
Jan 09, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Small crack in rubber seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 06, 2007 | Bosch WFR 145 Front Load Washer
Washing Machines Logo
1,102 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
